Question about Toshiba 36AF61 36" TV
Toshiba 36zp38b picture problems
I have problem with my tv when you turn it on its ok for about 5mins then the picture starts to roll then after about 10 mins of that the picture settles after a further 5 mins lines appear on screen and then it loses a colour items and people on the screen turn blue and this goes on till it decides to work .when it does work its perfect.its only 3 years old can anyone help me
  • jnamanga May 01, 2008
    Sergeant:
  • 308 Answers
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Posted on Mar 12, 2007
Wharfedale lcd3210af has started to switch off after 5mins... It will go straight back on when you switch it on and is a fantastic picture but goes back off after the 5mins again ???
does it turn of precisely after 5mins each time you turn it on? If yes, then there is every possibility that the TV timer is set to 5mins and when it gets to that time, the TV will eventually turn of itself.
But the TV doesn't turn off in exactly 5mins all the time, then it is having a power related problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
This is a common problem faced by many other users too. To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board.
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
You can buy this part at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor (capacitors) most likely the normal operation will be restored. Or you can buy a refurbished complete power board to save you some stress.
If this task is too technical for you, you can call a family or friend who has the ability to assist you (two heads are better than one).
Good luck.
Jul 10, 2011 | Televison & Video
LG 52" Rear projection TV
Probably something wrong with the lamp. Buy a replacement.
Mar 01, 2011 | LG RU-52SZ30 52" Rear Projection...
My 36'' Toshiba televisions picture keeps going fuzzy then if you turn it off and on the picture comes back on. Also when watching movies we lose the picture but hear the sound. Once again if I turn off...
I would start with the Tcon but the main would do this as well, along with the power board...test the voltages coming from the ps board when its giving issues and see if they are ok, if they are try the tcon board
Dec 11, 2017 | Toshiba 36A40 36" TV
When I first turn on the tv I get a degraded
Hi did you ever solve this problem? i have the exact same issue, i think its the main-y pcb but want to be sure. green pixels, slow refresh rate on screen, after 5mins the picture is normal till next time i turn it on.
May 25, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Manual for 36zp38b tv
http://tesc.toshiba.co.uk/Web/ModelLis.nsf/ByModel/22DA0684C6D527B980256D010056147C
That hopefuly is the manual you wanted. more information helps when posting a query.
Jun 23, 2009 | Televison & Video
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Toshiba 36zp38b
Hi.
Yes the dss module is very common to fail.
Unless you have proffesional soldering station & can work on ics whith 200 plus legs do not attempt to repair.
On ocaision if you moan to toshiba they will send A replacement module free of charge. I have had several come to our shop where Tosh has done this the module is just over £100.00 to buy.
All you need do then is pay to have it fitted saving over £100.00
Hope this helps
Chris.
http://dysonmanuals.llc.nu/index.htm
Mar 14, 2008 | Toshiba 36AF61 36" TV
Toshiba Rear Projection TV 42WT29B
This is a problem with the low voltage condition in the main power supply or the sweep supply, or there is bad capacitors in the vertical driver circuit, or the PIP circuit if there is one. the best way to troubleshoot this would be with a schematic, measure all the voltages and see if there are any lower then normal levels. In the vertical and PIP circuits, you will need an ESR type capacitor meter. if you dont own this equipment, or have had no experience working on solid state electronics, play it safe and call in a tech to assist you in this repair. Good Luck Please dont forget to rate this thread.
Dec 11, 2006 | Toshiba 42H83 42" Rear Projection...
Toshiba 36AF61 36" TV Logo
388 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
