Question about Zenith C27A24T 27" TV
My zenith tv's picture is shrunk to the middle of the screen, also it turns off after about ten seconds and won't turn back on..
  • 20 Answers
You have 2 problems 1 is that your power supply is going bad and 2nd is that 1 of your caps. is going bad. the capasater is what keeps your screen vert. and hor. the part for this is cheap but very dangerous to put in. sorry about the bad news. i had a tv do this to me and sometimes i could hit the side of it and it would be ok for a while. hope this helps
Posted on Jan 02, 2009
I have a zenith projection tv model r56w36. It won't stay on. When I remove the back panel and turn it on, I see a bright flash coming from the middle bulb on the right side of it where It looks
better be very careful here, if a pop or flash near one of the three crts or picture tubes there is serious voltage there.
the tubes each have a sealed wire delivering at least ten thousand volts to each tube===I have heard this before. likely what you have now is the seal they place where the wire enters the tube (2nd Anode) is arcing.
tube has to be removed to get at and reseal that--not a beginner or doit yourself job.
Note: if you keep turning it on sooner or later it will destroy other parts.
Sep 03, 2012 | Zenith R56W36 56" Rear Projection...
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
TV Model # C27A24T about nine or ten years old. TV
Bad grounds and bad caps will cause the problems in this tv. You will need to replace several caps and resolder the tuner itself and that means taking the tuner out in some cases and rework it. This is very time consuming and needs great care not to destroy the tuner. And reinstall the tuner to the board. You need the cap check to locate bad caps and visual to see bad grounds on any Ic on heatsinks. If you are a do it yourselfer fine.. If you cannot do this I would just replace the tv.
Oct 11, 2009 | Zenith C27A24T 27" TV
Tv picture is shrunk to the middle of the screen and turns off
if you mean line across middle no vertical deflection prob circuit prob. need tech.
Dec 13, 2008 | Zenith C27A24T 27" TV
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Feb 14, 2008 | Zenith C27A24T 27" TV
Line through the middle
socer, solder connections on the vertical output IC are broken, board has to be taken out and re-solderering the pins on the vertical IC will fix it easy job for a tv tech, good luck, BMW Rider
Jan 03, 2008 | Proscan PS36123 TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Zenith C27A24T 27" TV Logo
61 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
