Question about HP Hewlett Packard LaserJet P3005n Printer
ERROR MESSAGE 49.4C02 ERROR
  • Anonymous Apr 07, 2009
    service error 49.4C02 for hp4700n
  • 837 Answers
This error is usually caused by a bad formatter board.
But try the following:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Posted on Dec 13, 2008
xcanox
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
  • 17 Answers
SOURCE: problem with our printer 5200tn
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt data
during transmission to the printer. Other
causes include poor-quality parallel cable,
poor connections, or home-grown programs.
On rare occasions, the formatter is at fault
which typically appears as a 79 Service Error.
  1. Turn the printer off and then on.
  2. Press Stop to clear all print jobs from the printer memory.
  3. Turn the printer off and then on.
  4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message
only appears when using
certain software programs,
contact the software program
Posted on Dec 18, 2008
  • 154 Answers
SOURCE: Hp CM8060 error code 49
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
  • 4 Answers
SOURCE: Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Posted on Sep 18, 2009
seeker5211
  • 1089 Answers
SOURCE: service error 49. 4c02
Go to hp.com download and install the latest firmware.
Follow the directions.
Posted on Aug 22, 2010
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
HOW TO FIX CAMERA FAILED ERROR MESSAGE.HANDLER.HANDLE MESSAGE(-1)
ERROR HANDLER.HANDLE MESSAGE(-1)...CAMERA GALAXY YOUNG......!
Sep 12, 2012 | Samsung Galaxy Y
The printer will not print because of service error 49,4c02
Hello thanks for using FixYa
error 49.4c02 is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
Please see my this Solution (Same as your's), 2 people thought it as Helpful for them So
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 10, 2011 | Office Equipment & Supplies
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
Could not create this file.Shall I try again?
Click Start
Click Run
Type CMD and press ENTER.
Enter CD \ and press ENTER.
Enter CD "program files" and press ENTER.
Do you get an error-message?
If not, that's good. If so, what's the error-message?
Enter CD "PrintMaster 2.0 Gold" and press ENTER.
Enter CD "Components" and press ENTER.
Enter CD "Clip Art" and press ENTER.
Enter CD "Travel" and press ENTER.
Enter CD "Europe" and press ENTER.
Enter ECHO Y > "Rusty Fence.jpg" and press ENTER.
Jan 04, 2010 | Encore Computers & Internet
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
occurred that caused the
to abort operation. This type
of error can be caused by
corrupt data, or invalid
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
first program and try
the message appears
only with a certain
software program or
software vendor for
assistance.
4 If the message persists
programs and print jobs,
disconnect all of the
or computer.
5 Turn the printer off.
6 Remove all memory
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
DIMM and EIO device
off and on again as you
10 Replace a DIMM or EIO
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP Hewlett Packard LaserJet P3005n Printer Logo
836 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
