FixYa.com
Tags:
H.H. Scott SCR120 Clock Radio
Daylight savings time again
posted by ddddddddddd on Mar 11, 2007
can i disable my clock's ability to change the time? i want the time only to change when i change it.
Comment by ddddddddddd, posted on Mar 12, 2007
looks like i'm gonna have to get a new clock- but thanks for your help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
clockwatcher
Rank:Apprentice Apprentice
Rating: 97%, 3 votes
I had a problem with my clock today,Sunday,March,11th. I live in the Eastern time zone so I changed my clock to the next region East of this zone. Worked great...now at the beginning of April when the time usually changes, I will adjust my setting back to the Eastern Time Zone!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 11, 2007
Helpful (85)
Noggin
Rank:Guru Guru
Rating: 87%, 1458 votes
Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also -
The US clock says;
"I have a radio controlled clock that receives NIST time. Will the new rules affect me?
Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock.
I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work?
The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement.
If you need to contact manufacturer check
http://www.emersonscott.com/ezsetamclocr...
Hope this helps:)
Comment by Noggin, posted on Mar 11, 2007
1-888-837-8370
or email at: HHScott@emersonradio.com
http://www.emersonelectronics.ca/emerson...
this is for another model posted today but may shed some light on the procedure to change it if you are lucky
Comment by Noggin, posted on Mar 12, 2007
Sorry no real solution, but;
Don't throw it away though - check locally -there are always organisations that will take unwanted electronic gear and find a way to put it to some use - if in doubt check with your local garbage/rubbish disposal company and see waht they have to offer - if they are not inerested then make them be!
Not grinding an axe here (much) but hope you can find a better solution than throwing it in a landfill.
If you want to buy a new one, check the reviews on amazon.com type in clock radios and you get a lot of helpful info. - hopefully the dst problem will not happen again - although i read that the US might repeal the new dst law after a year or two if it doesn't seem to make any energy savings. maybe worth keeping your current clock until they change back. you can understand why the manufacturers are a little confused and chucking out things that don't work.
apologies again for not SOLVING your prolem, but I hope you get more luck again if you have any other issues for fixya.
Can you Help with these Clock Radios problems?
Clock Radios
Getting the clock off military...
I want the clock to display... Answer This...
Clock Radios
Collectible Talking Clock...
I have the product described... Answer This...
Clock Radios
gpx clock radio/cd player
i am unable to figure out how... Answer This...
Clock Radios
Set the clock on my RP4801A...
That pretty much covers it. Answer This...
Clock Radios
Westclox Travel Alarm
I bought a travel alarm clock... Answer This...
Repair Service
Find Clock Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
