Question about Yamaha DVD-S2500 DVD Player
Loading disk problem
The unit fails to read CD?s or DVD?s. Generally it will either continue to display reading indefinitely or sometimes it will ?restart? and display welcome, then try to read the disk and go in a loop, reading, welcome, reading welcome???? with one DVD it does recognise it as a DVD and plays 11 seconds of the info and then restarts to welcome.
SOURCE: DVR-S120 doesn't play any cd's
I have come across one DVR-S120 that has a shorted spindle motor. This is the motor that spins the disk. Therefor the unit will not play a cd or dvd. Yamaha sale's the complete dvd Assy. for $300 witch is absurd.
Posted on Jan 16, 2008
  • 236 Answers
SOURCE: discs not reading
maybe cleaning will make it work for a while. but basically your lens started to get poor focus and weaker laser. it has to be replaced.
Posted on Mar 31, 2008
SOURCE: we have a yamaha dvd player, model number dv-s5450
I had a similar problem...the machine, which had been great up until then, started to be very fussy when loading a disc; using a lens cleaner did not help at all.
I opened the disc tray and used a can of "air duster" with the straw attachment blowing in lots of air into every little nook and cranny that I could reach, especially in and around the actual lens area. The liquified gas under pressure must have been too cold as, at first, there was no improvement whatsoever when I tried playing a disc. However, the next day the player was working perfectly again.
It is worth a try.
Posted on Dec 08, 2008
SOURCE: DVD-S540 Player-disk not recognised
Had similar problem..used pure ethanol with a cotton bud on the lens for cleaning. Its been working ok for a while..But my problem is not 100% fixed yet as it still gives me hassle on ad adhoc basis. Maybe the solution of Seanrm might be a much better one....
  • 120 Answers
SOURCE: My dv s5770 (yamaha)takes a long time to read the
The lenses of your dvd has a dust on it. You need to buy a cd cleaner , or you have to open the dvd and locate the lenses. Clean the lenses using cotton buds with alcohol.
Posted on Jul 23, 2009
@Hello - whenever I try to insert a disk to play it starts reading it (display reads READ...READ and then it stops and displays HO7 and won't play the disk at all. I've had the unit a few years but have...
H07 is a common error code for Panasonic DVD players. It means the traverse unit (spindle motor/laser assembly contained in one block) has failed. Usually it is the spindle motor part of this unit which fails first, (i.e. it doesn't spin the disc at all) causing the problem, but sometimes the laser can also fail as well. Because the motor and laser are contained in one device block, the whole part has to be changed, and this can only be done by an authorised service centre. The only trouble with that is the cost. Many DVD drives experience this (different brands giving different error codes) so it's not just confined to Panasonic.
There are only 2 ways to go here; either be prepared to spend a fortune in a workshop service to have the traverse block replaced/aligned (which would include a brand new laser), or simply buy a new player - which would give you a new remote AND an optional extended warranty if available; this would be considerably cheaper than repairing the old one.
Don't be put off from owning Panasonic - they are generally good products.
Feb 24, 2011 | Panasonic DVD-RV32 DVD Player
HI when i put disk in cd rom drive the computer only reads for about 3 seconds and then the message says insert a disk..my son has been burning a lot of disks lateluy and not sure why it broke so soon,only...
Loading new device-drivers will not help.
In the first few seconds, the drive is trying to read the first few blocks of data from the media, to see if it is a "data" or "music" or "blank" CD. If nothing can be read (dead laser?) then you get the "insert a disk" message.
> do I need a new unit?
Yes; spend $40 to buy a new CD/DVD reader/writer.
Oct 11, 2010 | HP Computers & Internet
Dell Dimension 3000 desktop with Samsung SH-S182M DVD/CD-RW often fails to read disk in drive. Usually occurs with a data disk that has previously been written by the same drive. Almost always reads disk...
The drive's laser lens is dirty, try to clean it. If that fails to have an effect then the dirt has already been burned on the lens, unfixable, replace the dvd unit.
May 10, 2010 | Dell Dimension 3000 PC Desktop
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
Reads no disk
((((NO DISK))))
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Apr 13, 2009 | Philips DVP5960
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
D1817PKG DVD. Turn on unit - insert cd movie- audiovox loading - does not recognize cd
My dvd player tries to load dvd, then says Cannot Read Disk. Have tried different disks.
Jun 13, 2008 | Televison & Video
Displays "NO DISK"
The message indicates that the system failed to read the index portion of the disc. Try cleaning the lens using a cotton swab and alcohol. Try playing a music CD as well. If hte CD plays but the DVD continues to fail, you have a failing optics assembly that needs to be replaced. This is the most common symptom of failing optics. DVDs will fail while CDs will play.
Keep us posted.
Dan
May 29, 2008 | Apex Digital ADV3800 DVD Player/VCR
DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
Yamaha DVD-S2500 DVD Player Logo
59 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
