Question about Kenmore Dishwashers
Dishwasher willnot go on when I push button.
I checked the breaker and the connection and they are ok. No lights come on
I had a loose wire connection. It is now running. thanks
Posted on Dec 14, 2008
Not turning on
Remember KISS Principle......check your circuit breaker panel for a tripped breaker first. If that is ok, there is probably another circuit breaker or a fuse on the unit itself. Hopefully, you have the book that came with the unit. It will show you if you look at the parts diagram and parts list. If no book, go online to the manufacturers website and download a copy. They are usually available free of charge.
Mar 23, 2014 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Our dishwasher has power to it, however, when we try to push any of the buttons, nothing happens. We are not able to get anything, its almost as if the buttons are frozen. If you have any suggestions,...
Hello.
A lot of times due to the vibration of the motor the main power connection where the dishwasher connects to the house wiring the connection will burn off. To check if that is it remove the bottom panel and remove the cover to the junction box and check for burnt connection,it would be pretty obvious to see with the blackened wiring and the melted wire connectors. BEFORE DOING THAT TURN OFF CIRCUIT BREAKER FOR THE DISHWASHER. If the connection seems ok and not burnt up the most likeley cause will be a fuse on the control board has blown.
Good luck,i hope this answer helps you figure out why your d/w is dead,
Gene
Aug 05, 2011 | Dishwashers
It does not appear to getting any electric power. no light comes on. nothing happens when button are pushed. circuit breaker ok.
most likely your door switch is faulty check this first if it is ok may be the electronic board it may have to be replaced let me know how you went remember to turn of power before you open panel
Apr 07, 2011 | Haier Dishwashers
When I push the power button on the dishwasher, there is now no power and the dishwasher does not turn on and there are no lights generated. The circuit breaker has been checked and that is not the...
Try a fan or light where the washer is plugged in. Suspect a bad power plug connection if the test works. The next suspect is a faulty microswitch connected with the door latch mechanism. You will likely need a test meter to track this down. Good luck!
Aug 15, 2010 | LG 24 in. LD-12BW5 Free-standing...
My dishwasher has no power not even on the touch panel leds lights. I checked the connections.. Is there a reset button or a fuse i can replace or reset?
Check the appropriate breaker in your house electrical panel--push off, then on. If still nothing, look for a removable panel at the bottom under the door. Any internal fuses or breakers will be accessible there.
Sep 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Child lock light will not turn off on my kitchen aid dishwasher
ok shut off the breaker for at least 1 min if you have had a power surge you not know it can affect items then turn breaker back on and then push and hold the lock button some times up to 90 sec once you see lock go off then release the lock button then your back in business
Sep 06, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kenmore 16879 built in just stopped - no power at all now
open the bottom panel and check the eclect box see if you find any burnt off wire nuts if all is ok there you need to check the door switch.. TURN OFF THE BREAKER FIRST!
Feb 16, 2008 | Kenmore 16879 Built-in Dishwasher
Dishwasher stopped working
You have a board problem it came from a power surge.
Nov 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
35 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
