Question about Celestron NexStar 130SLT (31145) (306 x 130mm) Telescope
The computer guidance seems totally dead. The hand set can maunally power the motors to turn the telescope but the screen is blank.
  • miller-jim Dec 13, 2008
    Sorry my post was not clear.  I was talking about the hand held "computer" in the  supplied with the telescope.  There is no way I have to reload the software (and i have no software)  Do you know if thera are any key strokes on the hand held to reset the unit?
    regards
    Very fast help. Thanks alot
  • 13,433 Answers
Reconnect the telescope the to computer, are all the drivers properly installed? did it work before?
Posted on Dec 13, 2008
  • Ekse Dec 13, 2008
    there is a factory setting reset in the menu,
    The factory setting - return the nexstar hand control ot its original factory setting. Parameters such as backlash compensation values, initial date and time, longitude/latitude along with slew and filter limits will be reset. However, stored parameters such as PEC and user defined objects will remain saved even when factory settings is selected. The hand control will ask you to press O key before returning to the factory defaults settings
  • Ekse Dec 13, 2008
    User manual and also firmware update for the handheld unit are available on this page
    http://www.celestron.com/c3/product.php?...
  • 19,396 Answers
Reinstall the software completely.
If that does not work, it may be a cable problem.
  • 1 more comment
  • Ginko
    Ginko Dec 13, 2008
    If the motors can be manually powered, then the problem is probably the software installed on the computer, or at limit the connection cable.
    To start unplug telescope and computer power and connection cables for ten minutes, this is called hard reset, and can solve problems caused by electrostatic charges by draining power completely from the devices. If the computer is a laptop, also remove laptop battery at same time.
    After this, try doing a system restore to a recent date, chose a date before you started having the problem.
    Here is how to do system restore on XP, on Vista the procedure is similar.
    If system restore does not work, try reinstalling the software completely, using again the CD that came with the telescope.
    At this point it should work, if it does not , test the telescope and software on a diffeent computer.
    If it works , reinstall windows on first computer.
    If it does not work, get a replacement connection cable.
  • Ginko
    Ginko Dec 13, 2008
    Then it is not a computer, it is the Celestron sky scout you are talking about,.
    You need to upgrade software/firmware on your sky scout, see:
    How do I update my SkyScout software-firmware?
    and
    I can’t successfully flash upgrade my SkyScout. What can I do?
  • Ginko
    Ginko Dec 13, 2008
    You may also need to upgrade the motor control firmware, download is : Motor Control Firmware Updates v.2.1.21 (3.37 MB) release notes
    If the firmware update operation gets interrupted , the control device may result damaged.
    Better to contact celestron and find step by step instructions, and safety suggestions on how to do the firmware update before starting the update.
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
May 16, 2014 | MSI G41m-p26 Desktop Motherboard - Intel...
Blank screen
the wiring from the board of the camera leading to the screen is dead. It should be rapired by a technician so i suggest that you rather have it repaired by a pro then to try to fix it yourself.
Mar 13, 2012 | Cameras
I CAN'T SEEM TO GET ANYTHING ON MY COMPUTER OTHER THAN A BLANK S
Possibilities:
* broken connector where the power-cord connects to the computer
* dead CPU
* dead motherboard
My recommendation is that you take it (with both power-cords) to a local computer-store, and get it professionally checked-out.
Jul 16, 2010 | HP Compaq Presario V2000 Notebook
Motors won't turn
Are the batteries FRESH? if they are you may have a bad motor. Contact Meade customer service:
http://www.meade.com/support/index.html
It sounds like BAD batteries. Try new ones first before sending it to Meade.
May 15, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
Motors won't turn
Check for shaft locks being engaged, and for motor bearing issues.
Mar 28, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
Screen on Starfinder Handbox will not work
Contact Meade here:
Sep 29, 2009 | Meade Infinity 114EQ-DH Telescope
Asko T760 Dryer - Computer Screen Blank
you have either a frequency related issue or there is a lot of t.h.d. total harmonic distortion on the line, this will raise cane with electronics, I would try a power line conditioner on the dryer power circuit
Jul 30, 2009 | Asko T761 Electric Dryer
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dead screen
1 CHECK FOR VIDEO INPUT CABLE 2 CHECK BRIGTNESS,CONTRAST CONTROL FOR OPEN 3 IF IT IS CONNECTED WITH DVD CHECK FOR LEADS CONECTION REST NEXT TIME THANKS
Dec 27, 2005 | Emerson MT-1561 5.6 in. Car Monitor
Celestron NexStar 130SLT (31145) (306 x 130mm) Telescope Logo
32 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
