Question about PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame
Transfer pictures how do I load pictures from my computer to the frame, I cannot find my manual.
  • bailey99 Dec 24, 2008
    Frame not powering up
  • mommyofpiper Apr 30, 2009
    When I follow those directions, I get an error message saying that the disk is not write-protected
  • 333 Answers
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Posted on Dec 13, 2008
5 Suggested Answers
  • 75 Answers
SOURCE: how do I transfer pics from my computer to digital frame sv811
Connect the frame to you computer via the USB cable. Your computer should see the frame as a removeable storage device (new drive letter) if there's memory on the frame to store images. If not, then get a cheap memory card or USB key for $20 and put the images there.
Posted on Jan 11, 2009
robmcd27
  • 423 Answers
SOURCE: Need to load pictures from panditigal frame to flash drive.
Hi Doug, I'm sorry, but your pictures are stuck on the picture frame. There is no software on the unit to move them out.
Posted on Feb 21, 2009
Instant Help
  • 73 Answers
SOURCE: transfer pictures
Dear remove the write protection on your disk to eliminate this message, you computer or fram memory is write protected. check the properties of those and remove if they are write protected. this is resolve your issue.
Good luck in correcting your problem.
Best regard
Posted on May 27, 2009
benj888
  • 47 Answers
SOURCE: I can't transfer pictures from
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Posted on Jan 05, 2010
How can i take pictures?
You must take pictures and transfer them to a memory card using a computer. Here is a link to the manual: http://resources.kodak.com/support/pdf/en/manuals/urg00722/Digital_Frames_UG_GLB_en.pdf
Feb 05, 2015 | Kodak EasyShare EX1011 Digital Picture...
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
Transfer pictures from memory card
Ok what you need to do is you need to put your memory card into your computer/mac and down load the files once that is done delete the photos on your camera!
Mar 27, 2010 | PANDIGITAL 6.0-Inch Digital Picture Frame...
Transfer pictures
Best regard
May 27, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Cannot get my photos from memory stick to progess beyond the 1st 5 photos. they keep repeating. I never had a manual.
Hi there.
1st) How did you put the photos on your stick? Did you load them from a computer, or did you load them off a camera?
If you loaded them off a camera, did you format the card before you took the pics, or before transferring them from the camera's internal memory? You have to do format the memory card from the camera menu before it will work properly.
If you used a computer, same thing, you need to format the stick before you transfer photo's to it. Try it and let me know.
Rob
Mar 03, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Can't transfer music (audio) to the Frame
Make sure the music is in the correct file format for the frame. Some frames take MP3, others take WMA. If the format that you have is not compatible, you must convert it or the frame will not read it.
Jan 29, 2009 | SmartParts SPX8 Digital Picture Frame
How do I transfer pics from my computer to digital frame sv811
Jan 11, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Jan 10, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Transfer from computer to memory card
http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn029310.jhtml?pq-path=3906/2308/2316
you haveto install driver from above link..and then try to transfer photos from camera to pc...
after that from pc you can transfer to photo frame...
Jan 07, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Downloading pictures
Use an sd memory card. Transfer your pictures from your camera or computer to the card then put the card in the slot on the frame. You can buy them for as little as six dollars.
Nov 25, 2008 | SmartParts SPX8 Digital Picture Frame
PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame Logo
1,067 people viewed this question
Top PANDIGITAL Photography Experts
LP
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
