Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
A constant red tint problem (AV-56P787)
I was watching tv and then it shut its self off. It then turned back on by itself but instead of the normal black it was red. now most black backgrounds have a red tint. I tried doing convergency and then tried to change the tint and color. what exactly do i need to do.
  • Anonymous Mar 28, 2014
    I have had issues with my tv turning itself off every so often for months now but have always benn able to turn it back on and it was fine. But, now the problem is that there is discoloration in he screen, and it happened while was on. and now it stays discolored has like a yellowish tint. What could it be??
    Genius:
  • 1,139 Answers
This is an indication that the red gun is being driven too hard. Have you tried to adjust the red color control? If not try this first and if the control can not adjust the color then you will have to find out if the control grid on the red tube is working and has the proper voltages present. Which you will need the following equipment to do. Multimeter Oscilloscope Along with these you will need a schematic to show you what the signals and voltages should be. And I might also suggest having a pattern generator and using the color bar signal since more then likely that is the one being used in the schematic as the reference signal.
Posted on Oct 04, 2007
SOURCE:
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Sansui 13" DTV1300 shuts itself off
My girlfriend had the same issue with her 1300a. We saw on another forum that they took off the extra AV panel and infared receiver, so we opened it up. We couldn't really find either, but when we tightened all the plugs up things seem to be working fine again. Back to watching the Lifetime channel :(
Mar 18, 2009 | Sansui DTV1300 TV
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
I have an xbox 360 which is defaulted wen i turn on instead og green light there is a red light too.
turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
Jun 30, 2008 | Video Game Consoles & Games
Jvc av-48wp55 shutting off on its own
Is pix ok before shutdown?
If convergence is wildly misaligned then load may be shutting down power supply. Fix convergence and TV OK.
or
Poor solder connections on main chassis near FBTX and h drive. Needs expert solder work
easyab@hotmail.com
calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 14, 2008 | JVC AV-48WP30 48" Rear Projection...
Keeps turning off-Philips 50PF9431D
63 inch samsung plasma turn off then back on buy its self
Nov 14, 2007 | Philips 50PF9431D Television
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
241 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
