Computers & Internet Logo
Posted on Jul 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can get inside again in the boot setup of a dell optiplex 170L?
My pc (a dell optiplex 170L) cannot recognize mi cd player but mi os (wxp) run without problem, so I change the boot setup to test the recognition, i saved the changes but when pc reboots, it display me a diskette failure message and os(wxp) does not start like before this modification and I cannot get in boot menu anymore. Any solution?
Otulagun D. O.
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 129 Answers
  • Posted on Jul 23, 2012
Otulagun D. O.
Expert
Level 2:
Mentor:
Answers
129
Questions
0
Helped
14009
Points
381
Good Day,
That is quite an easy thing to do.
Immediately you turn on your PC, after displaying the brand (for some PC), the computer dispalys 'press F__ to enter boot setup'. If you can't get to read it, either press F2, F12, F10 or F1 continously after you turn on your system. Then you can make your corrections.
I hope this helps. Thank you for using Fixya.
5 Related Answers
Anonymous
  • Posted on Oct 08, 2008
SOURCE: dell optiplex 170L hard drive recognition
Ms Driver gets flaky sometimes. Get New driver from Dell Downloads.
Contact Dell Support for more INFO
Anonymous
  • 903 Answers
  • Posted on Nov 17, 2008
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
clokker
markus
  • 253 Answers
  • Posted on Nov 22, 2008
SOURCE: Diskette driv 0 seek failure
press f2 go to the boot priority and select harddrive to the first boot.
Anonymous
  • 153 Answers
  • Posted on Jan 09, 2010
SOURCE: my Dell optiplex 170L keeps turining off and then
Possible that it's caused by a faulty hardware or a computer virus on your computer. For us to isolate the issue we must start troubleshooting with the hardware
1. Remove all the connection at the back of your computer
2. Power cycle your computer tower by pressing the power button for 15 seconds
3. Plug the power cord back in and monitor cable at the back of your computer tower (if it turned on, meaning that one of the device plugged at the back of your computer is the one's causing the problem, for you to pin point the problem, try plugging it one-by-one and turn on the computer each time you plug a device)
4. If it keeps on doing that, open up your computer tower (be careful to unplug the power cord and power cycle it to avoid static electricity)
5. Reseat the video card, turn on the computer again, if it's still occurring
6. Reseat the IDE/Sata cable of your hard drive and try to make sure it's properly plugged in, turn on the computer again, if it's still occurring
7. Reseat the memory, turn on the computer and test it again if the same thing
8. If you have 2 memory chip inserted in your computer tower memory slot, remove the other one and turn on the computer, do the same thing to other memory and each slot
9. If all else fails, restart the computer and keep on pressing F8 before the window welcome screen comes up - to go to advanced boot options
10. Boot to Safemode
11. If you are able to boot to Safemode
12. Login as administrator
13. Click start
14. run
15. type msconfig then press enter
16. click on startup tab and click on disable all button at the bottom part
17. Restart the computer and let it start normally
18. if the same thing happen, boot to safemode again
19. Login to administrator again
20. Right click my computer
21. Click on properties
22. Click on Advanced Tab
23. Click on settings button under Startup and Failure
24. Uncheck the Automatically restart under System failure
25. Restart the computer in normal mode
26. Tell us if you see any blue screen error, if so, post the error here
if all else fail, your operating system needed to be reinstalled and you should have the cd for the operating system if it's XP or Vista or Windows 7.
Chris
  • 197 Answers
  • Posted on Jan 22, 2010
SOURCE: I have a dell optiplex 170L and i can't get it to
You have contracted a virus that has corrupted your "userinit.exe" file. This is why it logs you out right away. Unfortunately, you are going to either need to get your hands on a Windows install CD or will have to slave your hard drive to another computer. Instructions on how to recover from the log out problem are contained near the bottom of the page at the link below...
Once you solve the problem, you will need to get yourself a good antivirus program and get that system cleaned, pronto...
LINK
How can i do bios recovery in dell optiplex 170L
You should take out CMOS battery and wait for some time, replace it and BIOS should be reset to factory condition
No boot device available dell optiplex 170l series
Go to the bios to verify that the computer is recognizing the hard drive and that the hard drive is is listed in the boot sequence. If this is all good your hard drive may have been formatted or erased or the boot record is corrupt and unreadable to the bios. I had a similar problem. reloaded windows and all was good.
1helpful
How can I clean the hard disc & re-install windows on my Dell Optiplex 170L computer?
Put the windows cd in the cd drive. Restart your computer while pressin Del or F2 to go to the system BIOS and go to Advanced BIOS settings and go to boot order or boot sequence, select Cd/Dvd to be the 1st device on the list. Hit F10 to exit. Your computer will restart and boot from the cd. On the first screen, just press enter. Then F8 to accept license agreement. Then you will press esc. Select the partition that you want to clean up! Select the first option (quick NTFS), then press F to start formating! Wait and follow the instructions on the screen.
How to boot from a USB CD/DVD ROM MY System is Dell Optiplex 170L Thanking in advance
If you want to boot from a external cd/dvd rom here's what to do.
  1. Connect your USB CD/DVD ROM to your computer.
  2. After connecting, you must start from boot up. so Reboot your computer.
  3. You must go to your bios settings, so during boot, press DELETE or if it doesn't work reboot again and try F2.
  4. Now once on the bios settings, search for the boot device, or boot priority.
  5. You must make your USB CD/DVD ROM as First boot, or just place it at the top of the list.
  6. You can adjust the position by pressing (-)minus and (+)plus signs in your keyboard.
  7. Now once the USB CD/DVD ROM is at the top. press F10 to save the changes and click Yes.
  8. And that's it. Your PC will now boot from the USB CD/DVD ROM.
Goodluck, Hope my solution will help, Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a Great Day!
3helpful
3answers
Forgot password for Dell Optiplex 170L Os win xp
Boot the computer, while on the Del logo, keep on pressing F8 to enter the system on board.
1helpful
I have a dell optiplex gx 620 i install a new harddrive put the os cd in it said no boot device,i put in the dell boot cd it booted the computer up it got to A> prompt and stop loading what do i type in...
First put your Windows CD in the drive.
While booting, the screen should offer you a couple of choices - Enter "Setup" and tell you which keys to press or "Boot Options" and again which key to select.
Try Boot options first, and choose to boot from CD. It will revert next time you boot.
If you choose or have to enter "Setup" . Usually achieved by pressing the "Delete" or "F2" key look for and change your boot options to select you CD drive first but make sure you put it back later.
You may have to re-boot a couple of times to find the commands I mention, they do flash through fairly quickly.
2helpful
Hi, My Optiplex 170L BIOS has stopped recognizing my CD/DVD player ("Unit not installed"). The unit still functions in that the drawer opens and closes with the light flashing. I have downloaded and...
Ok this is commin.....
1 try a different CD ROM.
Or the mother board controler has dead.
Hopfully it's just the rom
PS...This asumeing you haven't installed another IDE device on the same ribbon cable
1helpful
I have a dell optiplex 170L and i can't get it to boot into windows..won't go into save mode either..keeps trying to log in then immediately saves my settings and we're back to the log in screen..i don't...
LINK
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
