Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
My color pictures are light and not colorful.
My printhead has been replaced three times. The same problem happens - the color is lifeless. I have done a full cleaning both basic and deep and then the color comes up yellow. It is awful.
i don't know what to do.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    What kind of cartridges are you using?
    Refills or Kodak brand?
    Problem Solver:
  • 3 Answers
Maybe you are not using Kodak cartridges, however I know someone who has had the printhead replaced 6 times untill the problem was solved with a new printhead, I would phone Kodak and ask them to replace the whole printer in case it has a manufacturing fault, ! A brilliant printer when working but too many problems arise in use.
Posted on Dec 17, 2008
Canon Pixma ip3000 will not print in color. We recently replaced all three color cartidges and when I went to do a nozzle check, it only printed the black part of the test page. Several times. I went...
I find this an unusual problem but lets look at the logic.
It worked ok before your replaced the colour cartridges.
Your replaced only the colours and now it does not.
Did you replace the cartridges with like for like?
Are they compatables? Did you run the cleaning cycle?
Run the cleaning cycle at least 3 times.
If still no good buy 3 genuine canon cartridges and see what happens.
If still no joy then must assume the printhead is the problem.
A bit of a coincidence?
Aug 11, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
According to the description, the color wheel went out. Loud humming noise, color distortion. I got a color wheel and first, by mistake opened the back of the screen, tilted it out a little way and...
did you install the correct color wheel? Most of the samsungs had retooled bearings in some color wheels and often a jumper has to be installed for the color wheel to work properly. Your wheel should be a BP96-01103A another thing that can happen is the thin brown ribbon cable can get plugged in backwards and will prevent the color wheel from working also. That ribbon only has contacts on one side of the ribbon. I would double check that if the correct color wheel was received for your model.
Aug 08, 2011 | Samsung HL-R5668W 56" HDTV
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My pictures are all printing with a purple look, such as water, clothes, sky, etc... There is no other color hue, besides purple in the picture.
Issue on kodak AiO printer not printing correctly you need to contact kodak support line at 1 800 421 6699 for printhead replacement.
Step that you can try
1. Clean Printhead twice press Copy button and Cancel button at the same time for atleast 10sec or until the printer move. Note cleaning printhead will consume your ink.
2. Reseat Printhead open the printer access door remove the ink cartridges and the printhead then close the printer access door wait until red light flash on the printer open the printer access door insert back the printhead then ink cartridges
3. Replace printhead contact kodak support
Nov 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
New ink not working three different times buying it and taking back ink very light or none at all no red it shows up yellow?
Have you done the cleaning the printhead? if not please run your clean printhead, if your using 5100 printer you can only do clean printhead by launching your home center, just click the help icon(?) under that click maintenance for you to able to see clean printhead
Now if you already done with this torubleshooting and still you haved incomplete color or incorrect colors printouts it means you printhead is defective., YOu need to call kodak tech support for printhead replacement i think its free of charged 1 800 421 6699 ext 05 toll free
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Copier wont print color picture from computer
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
Jan 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printerhead need replacing
Printheads are very sensitive and HP sets a "Time" limit of about two years for # 11 printheads regardless of how much you print. ( This is bunk from HP of course!.) But the prinheads do not expire!! They just show their health and that the printhead has exceeded the warraty period ( regardless of how much you print) .
Remove the printheads from their socket and fill a 8- 12" dish with 1/4" high of warm water. Set the printheads in the water in the same position they are set in the printer (vertical) You may need to place a wooden spoon of a block behind the printheads to keep the heads in position, as they will tilt backwards.
Leave the printheads to soak for about 15minutes.
Remove the printheads and slightly press them on a folded kitchen paper towel .It should show two lines of the same color of the printhead (cyan, yellow, etc) If the two lines are not of the same length (about 1/2" long) then repeat the soaking for that color. Be sure to dry the printheads properly
Install the printheads in the printer socket vertically so the contacts are properly set.. If not you may get a message to "Install (color) printhead". reset it again and run at least 15 pages with color information. It should print ok!!
If any print heads is damaged then the only option is to replace it with a new one.
It may be that the ink line from the cartridge to the printhead is clogged and ink is not flowing. This may require to run a large print job of about 50 or so pages to force ink into the clean printheads.
The terminal strip behind the printhead that makes contact with the pins in the printer are very delicate and if removed two to three times may not make a good contact and render the printhead unuseable.
Good Luck!!
JoeA
Dec 05, 2008 | HP Business InkJet 2800 Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Canon ip4200 colour magenta
the colors transfer to the printhead by gravity. the felt on the inktank must make intimate contact with the stainless steel filter in the printhead. I have a pixma ip 6000D that I had to replace the printhead inside of two years three times. the bubblejet circuitry in the printhead got burned out. New heads cost from $55 to over a hundred.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
