Question about Epson C64 InkJet Printer
I have epson i was given i have just put new ink in and it prints but with no ink
  • 353 Answers
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself. You will see a small oval rubber cup that covers the print head when it is parked. Use a syringe or dropper to fill the cup with cleaning fluid, then gently push the print head as far into the parking position as it will go. Then leave for at least 24 hours. Then try the cleaning cycles again. If no joy after this, report.
Posted on Jan 31, 2009
Epson Stylus SX515W black will not work. Put in a new cartridge, still would not work. checked it was in correctly, etc and all the time when the cartridges are changed it recharges. Have got through a...
From: https://www.computing.net/answers/hardware/epson-styles-nx420-printer-wont-print-black/85723.html
...I figured it out for my printer today... just got new ink, had the same problem, saw these posts getting me nowhere, so I figured ok the ink cartridge is fine... so what else is between that and the paper. I decided to go out on a limb and get a paper towel and clean off the little plastic nubbin that's inside the printer (the part that sticks into the cartridge, sticking out from where you place the ink) and it printed completely perfectly after that.
Apr 05, 2017 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus C84 prints every other line.. Cleaned print heads and ran nozzle check...still same problem.
Your printer head may be booked. Follow the instruction given bellow:
1. Open printer cover and put off cartige from cartige chamber.
2. Take a plastic seringe with full of ink and fit it on head's stick. Then push ink carefully.
use this procedure one after another . I thing you may relive from your problem. thank you.
Aug 17, 2010 | Epson Stylus C84 InkJet Printer
I put new ink in it, now it won't print, it is
If you only filled the cartridges with ink they will not work.
The chip on the cartridges needs resetting.
To do that you would have to buy an Epson cartridge chip resetter..
Feb 20, 2010 | Epson Workforce 30 Laser Printer
My Epson Stylus Color 880 printer won't print with ink
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. I hope this helps you.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 24, 2010 | Epson Stylus 880 InkJet Color Printer
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Sep 07, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson stylus color 760 failing to print.
you can take it to repair shop and they will clean the head for you with some cleaning fluid if it has been without ink for a while sometimes these get blocked but it is not worth replacing cus would cost more than the printer as the ink cartridge you brought was originall then this isnt the problem check all cables if not better off buying new printer as these are not made to last long sorry couldnt be any,more help...........................
Nov 05, 2007 | Epson Stylus Color 760 InkJet Printer
Epson C64 InkJet Printer Logo
69 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
