Question about Samsung SF-830 Plain Paper Laser Fax
Black vertical lines issues on Samsung multifunction fax SF
I have a samsung SF multifunction my problem is the black vertical lines on copies and fax how to get rid of it?
    Problem Solver:
  • 18 Answers
Black lines are usually a sign that you have toner on the laser slip glass which is usually situated above the drum unit, its just a little bit of glass if u give this a wipe and get toner on ur finger or rag then thats probably what wrong. If you don't I would look at your drum unit as it might not be cleaning correctly, which would mean getting a new one.
Hope you find this info helpful. Cheers
Posted on Dec 13, 2008
Why does samsung sf 2800 page come out black when copying a document?
if it receives faxes fine then its
likely the ccd reader input is disconnected . broken lead.
the sensor is above the slot where you insert the to be scanned sheet.
you'll have to open the case cover to find out.
Aug 03, 2014 | Samsung Office Equipment & Supplies
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Wide black line down page
open the document lid. Check to see if there is white-out on the glass platen where the document rides across the scanner. Some units require the white roll to be taken off.
sometimes a black mark on this platen can leave black streaks on copies made on this machine, and even when they send to others.
Try to clean the platen glass.
Oct 15, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
Samsung fax copying - line on middle of page
check if there is any kind of leank inside the printer. do a manual servicing once.
Jul 28, 2009 | Samsung SASSF560 - SF-560 Plain Paper...
SF-560R
CLEAN THE GLASS UNDER THE PART THAT YOU PUT THE SENING DOCUMENT INTO
MOST OF THE TIME THE GLASS HAS WHITEOUT ON IT
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Samsung sf-340 user manual
Link to SF-340 User Manual:-
http://downloadcenter.samsung.com/content/UM/200609/20060925101938281_SF-340series_English.pdf
Reason you couldn't find it on Samsung website is they have it under "Multifunction Printers". ....?!! don't ask me!!
Gingan
Aug 27, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Samsung sf 330
If you open up the feeder door (Where your originals feed into) you will see a slit of glass going from side to side by the feed rollers. (you might need a flashlight to see it better)
On the slit glass there is probably some white out or something on the glass. All you have to do is clean the glass and this should take care of your problem.
To help you zero in on where the marks might be located, make a copy of a white piece of paper through the fax machine.
And then line up the copy that comes out with your black marks to the feeder.
This should get you in the general location.
If you have any other questions, feel free to post another question.
If I have helped you, please post a feedback and a rating.
Have a good day.
Good luck.
Mac
Feb 23, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Title misleading: not a printer at all
Wow you are correct there.
This looks to be a tricky use of words, it is called Multi-purpose not multifunction.
Thats extremely interesting but here is the marketing info.
Sorry you were mislead on that one.
Marketing Information The SF-560 laser facsimile is a multi-purpose office solution that combines the power of Samsung technology, with a combination of faxing, copying, and scanning. The stylish and compact SF-560 is easy to set up to immediately tackle your most demanding office needs.
Dec 20, 2007 | Samsung SF-560 All-In-One Laser Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung SF-830 Plain Paper Laser Fax Logo
161 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
