Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint ultima washer dryer
Got a second hand washer dryer yesterday, it done one wash, then when i put it on a second time,it made a bang sound and it flipped my electric.when i flipped the switch back, it came back on but it won't work because it keeps saying close door, but the door is closed.can this be fixed easily, and what is wrong
    President:
  • 1,462 Answers
Isolate from mains. undo door gasket and check interlock id ok. interlock is mounted on cabinet on rhs
Posted on Mar 22, 2007
Hi, i got a hotpoint ultima extra washer dryer, code WDM73, it does a wash but at the end of a cycle it wont drain the water, it says check the outlet pipe but theres nothing wrong with it, i dont have a...
try bottom front right hand side is a filter ,...undo ..water will come out so have some towels ready... clean and refit... bsc appliances 07779933829 spares and repairs.
Feb 27, 2011 | Hotpoint Washing Machines
Hotpoint washing machine. Replaced drive belt yesterday but fell off again during cycle. Also tightened up pulley. What have I not done?
You most likely didn't tighten up the belt tensioner, this adjusts the tightness of the belt, so as it stretches, during use, this can be, adjusted out.
Apr 07, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Re Hotpoint Ultima washing machine
this is a common fault you can get hotpoint to replace the board at a cost of £90 or buy a second hand board for about £40 sorry but this is your only option without sending your board to qer
Jul 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wash/dryer wf860
Press "end of cycle" button for over 5 seconds, the child lock comes off. Press it again and the child lock comes on, this works for Hotpoints, you could try, no harm.
If it works, pl rate me.
Nov 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 stops every time with 1 second to go
This problem is caused by the heating element not working.The machine won`t spin & finish because the machine knows it hasn`t heated the water during the wash programe but clock will still count down.this is what we were told by a hotpoint engineer.the callout charge is £89.98 from hotpoint this includes parts & labour. 27/7/07
Nov 05, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
114 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
