Lite-on dvd rom driver is corupt, i have uninstalled and reinstaled the driver through my computer wizard and troubleshooter and it tells me it canoot install properly as driver corrupt or missing.
  • 112 Answers
Get the fresh copy of your driver from internet
and reinstall again
if you are unable to get driver tel
Posted on Dec 14, 2008
THE DVD TRAY NOT OPENIG
make sure that the cd rw/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back in this should activate the found new hardware wizard
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click to update driver
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps you
Aug 01, 2011 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My computer looking a support in this device------>>> what shoud i do?????
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 09, 2011 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
My dvd rom not showing in nero programme
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 24, 2011 | LG GDR-8164B 16x DVD-ROM Drive -...
Will not recognize cd's but plays and records dvd fine
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device also scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
hope this helps
May 15, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Primero mi lectora Lite-on LH18A1P no leia dvd asi q la desarme y le gire un cuarto de vuelta hacia la izquierda el tornillito de calibracion de dvd. ahora los lee perfectamente, pero no graba dvd, cual...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 01, 2011 | Lite On LH-18A1P DVD RW Dual Layer Burner
Hp dvd rw ds-8a1p drive driver please
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
hope this helps dont forget to vote
Mar 12, 2011 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Dvd driver
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
if your computer came with a disc the drivers could be on it
hope this helps
Feb 15, 2011 | Computers & Internet
My driver cd is correpted i want the drivers
if your computer came with a motherboard disc the sound drivers could be on it
hope this helps
Jan 22, 2011 | Computers & Internet
Need drivers for a dh52c2p computer crashed need drivers thanks much
if your computer came with a motherboard disc the drivers could be on it
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
Jan 09, 2011 | Lite On DH-52C2P-08 CD-RW/DVD-ROM Combo...
My cd-rom can't read CD-R??!
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Nov 25, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
Computers & Internet Logo
David Payne
David Payne
