Heil sp80 gas furnace - burners won't stay lit
10+ year old furnace. system turned on, had to relight the burners, ran for a few minutes, burners keep going out, but system keeps running.
  • sbradley29 Dec 25, 2008
    Christmas eve mine also started acting up. When thermostat signals to come on and the air purge (I guess) starts, the electric ignitor will not start glowing, or if it does it only stayed lit for a few seconds long enough for the gas to kick on (5 at the most) and then unit flames out. Is it the thermacoupler or what?
  • Ken Bledsoe May 11, 2010
    Does the system run for 30 seconds or like you said 4 or 5 minutes?
3 Suggested Answers
  • 25 Answers
SOURCE: The furnace burners won't stay lit
Could be a couple things. First and easiest is to check your intake combustion air supply. If it is blocked by anything or just not enough flow, it will put out the flame. Next would be the flame sensor, usually a temperature probe near the flame front. If it's not reading an increase in temp within a pre-programmed time, it will kill the flame. It can be checked with a multimeter.
Posted on Jan 25, 2008
SOURCE: Furnace burners wait too long to come on
Sounds like the burners need to be removed from the furnace and cleaned thoroughlyto help with gas distribution if these are in-shot burners they look sort of like an air plane, they have a cross over tube on each side of each burner and if that is rusted up the gas will not distribute evenly from one burner to the next if the pilot and burners go off at the same time then it sounds like you may have some flame blow back maybe due to soot build up in the heat exchanger. Overall sounds like your furnace could use a good servicing
Posted on Oct 16, 2007
Furnace goes out when blower should start
There is a sensor called a pressure switch that is attached to the area of the blower motor for the exhaust fan. It is bad or plugged.
Nov 16, 2015 | Heating & Cooling
Blower Motor for Ignition keeps going after Furnace Stops
That sounds like a control board problem. If your spare is an exact match, I would try swapping out that board.
Feb 19, 2018 | Heating & Cooling
Where is my flame sensor on a single burner coleman evcon high efficiency furnace
If this is a hot surface ignition system, the sensor may also be your igniter.
Dec 11, 2013 | Heating & Cooling
Vulcan Quasar wall furnace, pilot will lit and burner starts but goes out after a few minutes. sometimes pilot will relight but most often fails to light till unit cools down. Any suggestions?
You may need a new thermocouple if you have been able to light it before.It is located above the pilot lite and needs to get hot to keep the gas flowing.You can pick up a universal thermocouple a the local hard ware store.Shut the gas off,unscrew the coupling nut and remove the old one.Bend the the new one like the old one and replace.Try not to kink the new one.Good luck and thanks for choosing
May 15, 2011 | Heating & Cooling
The furnace will kick on and the burners will keep going out the process will continue unless i shut the power to the furnace off for five minutes then cut it back onit will run good but the problem will...
check your air filter, a very dirty filter will cause the unit to over heat "180'" The burners turn off the unit cools itself with the blower and then relights.
Jan 24, 2011 | Goodman Heating & Cooling
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Heating & Cooling Logo
594 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
