Question about NexxTech ESDVD100 System
DTS Sounds Like Crap.
When i select the DTS audio setting on a DVD that has DTS it sounds like the channels are switching from speaker to speaker. The sound also goes low then high at the same time. When it's in any other audio setting there is no problem. I had returned one unit back to the store only to get another one with the same problem. I have just chalked it up to that this is because it's a bad batch of systems manufactured. So i just watch movies in 5.1 instead. But if there is a way to fix the problem then that would be great.
3 Suggested Answers
  • 45 Answers
SOURCE: Nexxtech ESDVD100 DVD player gone bad, how to replace?
You can try cleaning it with a dvd disk cleaner first. If that dont work by a cheap dvd player and run it to the inputs on the back of the surround player.
Posted on May 24, 2010
lock123
  • 6831 Answers
SOURCE: The background music of the
Hello
Yes, fortunately this is only a minor setting which needs to be set right. Although i have never worked on this unit before, all you need to do is to have a look on the remote itself.
The problem is that the player is set to play through the wrong channels. Hence, you can hear the background music and sound, but not the voices. This is because the voice is sent to a channel which does not exist.
On the remote there is usually a button saying channel or sound channel...Something in this line. This will enable you to cycle through the sound channels(2.0 ; 5.1 ; 7.1 etc)
If you cannot find this button on the remote, you will need to have a look around in the sound setting menu.
Hope this can be of help.
Kind regards
Andrea
Posted on Aug 14, 2010
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
Everytime I use the DTS functions to enable my surround sound, no sound goes to my speakers. I am able to use it only for the standard output with the left and right front speakers. What could be causing...
DTS should be enabled only if your source has a DTS digital audio out connected to the receiver.Mostly only DVD / Bluray players have DTS sound and is outputted through an optical or co-axial port on the back of the player. Its a multichannel digital encryption technology where the signal is sent through one cable and your receiver decodes it into 5.1 or 7.1 channels according to the source.
Apr 22, 2011 | Pioneer VSX-D810S Receiver
Ok, I bought some Gigaware speakers (8watt GigaWare 2.0 2/bass subwoofer) and they work just fine, playing internet content and MP3s- until I try to play a DVD. Then, one channel of the audio disappears-...
A couple of things I would check first..
Obviously the settings on the movie audio settings themselves.. the default may be dts or some such thing.
Next.. open the control panel. clik on Sound.. make sure you check all the settings.. clik on the speaker icon and clik configure..
Also check the settings via your sound card software interface.. it sounds like something is set to something other than simple Stereo.. like 5.1 or 7.1 etc.
I doubt it's the dvd player itself.. or the dvd.. more than likely it is a simple conflict in one of the above settings
Good luck
Feb 26, 2011 | Computers & Internet
When DVD uses DTS Sound, doesn't use 5.1
The bitstream sent out by the BluRay player is selectable via menus on thedisk. And the player itself may have a menu that allows it. Would need to know more about the source.
Feb 21, 2010 | Technics SA-DX950 Receiver
I am not getting the full surround sound options. With DVD movies the actors voices/conversation can not be heard except on All Channel Set or Stereo options. This used to work. Ive added Optical audio and...
On the remote try scrolling through the settings from the DTS button and also make sure you have the correct audio source selected. I switched to the optical cable but, then found that the better sound for my room came from the RCA set-up.
Good Luck and I hope this helps.
Oct 04, 2009 | Onkyo HT-S680 System
When playing dolby digital 5.1 surround dvds it.is not getting decoded.i get the sound in all the speakers.
go to your control panel
click the sound icon
under the playback tab select the audio device you want to configure
right click properties
check each tab make sure you have dts / dd ticked
you may have software from creative installed check this to make sure you have the soundcard setup to output 5.1 when available
make sure the sound is configured on power dvd
if you cant get it working that way i suggest trying windows media player 11
also remember the soundcard will only output 5.1 if the source is 5.1 a copied dvd for example could be 2 channel stereo
i hope this helps you out !
May 28, 2009 | Creative Labs Sound Blaster X-Fi Xtreme...
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Sep 22, 2006 | Yamaha RX-V550 Receiver
NexxTech ESDVD100 System Logo
47 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
