MY PRINTER COPIER IR-C3170 IS NOT WORKING DUE TO THE ERROR -E000070-0001, I NEED HELP TO RECTIFY THE SAME
Not a good code to have. Its a problem with the transfer belt home position sensor or maybe a broken tension arm. The disassembly involved to remove that belt assembly is brutal and the belt assembly is expensive also. Love the canon copiers but the c3100 and c3170 units are terrible machines. I would think twice about investing the money it will take to repair it.
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
SOURCE: ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
SOURCE: canon ir-c3100 copier error code
The ITB or Intermediat Transfer Belt is slipping or not being driven properly. It is NOT fun to take out, particularly if you have a finisher attached. If you have proffessional experience with copiers and are really determined, let me know and I may be able to set you up with a manual. Otherwise, call a pro.
SOURCE: Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
