Question about LG Flatron L1710B 17" LCD Monitor
Black marks on screen
There are two black marks on screen about 8 inches long. The marks look like someone has taken a marker pen to the screen. Is there any way to purge the screen/clear them down?
  • Anonymous Aug 08, 2008
    MY MARKS ARE FROM MY GRANDDAUGHTER SHE DID IT WITH A PEN
    Champion:
  • 220 Answers
This is normally a problem of panel.you need to replace the panel.
Samir
Posted on Mar 10, 2008
How can check air rifle power
If the gun barrel is dark, use a grey or silver paint marker to put the check mark on the rifle, but if the barrel is light colored, a black permanent marker should work fine. If you ever need to take the mark black off, come back and ask how (for free again, of course)!
May 08, 2017 | Optics
Why is my screen black?
SONY CUSTOMER SERVICE:
800-430-4433
Press 5, then 0, then 0
Average Wait: 10 mins - Mon-Fri 9:00am-8:00pm ET
Sony Repair or Exchanges
1-888-222-7669
FROM WHAT I HAVE BEEN READING THIS WAS A RECALL A COUPLE YEARS BACK BUT NO LONGER.
Aug 05, 2012 | Sony Cyber-shot DSC-S730 Digital Camera
I'm getting black lines when I print or copy on my Ricoh Aficio 3228C. It looks like they're caused by the rollers. Does anyone know how I can clean or resolve this issue?
looke my friend black lines have many reasons on of various reasons rollers in fusing unit may be scratched if it like that use marker black pen and put pen in spots of scratch area sconde reason pcr primary charge roller and scanner filter
Feb 09, 2011 | Ricoh Office Equipment & Supplies
My hp lazer jet 1600 is making big black horozonal
Measure your marks and replace whatever is indicated by this chart.
Measurement Component
24.7 mm (0.97 inch) Developer sleeve
26.7 mm (1.05 inches) Charge roller
32.9 mm (1.3 inches) RS roller
37.7 mm (1.48 inches) Transfer roller
54.5 mm (2.15 inches) ETB rollers
56.6 mm (2.22 inches) Fuser sleeve
62.8 mm (2.47 inches) Pressure roller
75.4 mm (2.97 inches) OPC
Nov 09, 2009 | Office Equipment & Supplies
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
Projection tv has 2 pictures split with 8 inches of black
IN THE MENU GO TO COLOR CONVERSION OPTIONS AND TRY THAT ,,ALSO TRY NEW CONNECTERS
Apr 24, 2009 | Panasonic PT-52LCX65 44" HDTV
Hitachi 57inch tv 4 years old has a black mark on the screen
Thanks for your reply. The only thing that causes marks like that is usually the glue that holds the lenticular screen and the fresnal lens together heats up and drips (or slides) down. There is usually a strip of black tape that seals the two pieces of thin, glass sheets. This allows for easier installation and keeps debris from getting between screen and lens, however, someone overlooked the elements of heat and aging on this tape.The screen and lens can either be replaced or disassembled and cleaned. They are very expensive, (a few hundred dollars each), and disassembly can be very tedious. One caution I must give you is to make sure if you seperate the screen and lens make sure they go back together facing the same way. Try to clean only with warm water and a few drops of a very mild cleanser like dawn. If all else fails, you can buy a used screen sometimes from a local factory authorized service center. Occasionally they save the ones that are in decent shape. I have one 57" screen here in cincinnati that would work. Good luck, Russmann.
Jan 09, 2009 | Hitachi 57F500 57" Rear Projection...
NEED COLOR DISC RED GREEN BLUE CAN YOY HELP
You can use a samsung colour wheel on the Sagems (Part no.BP96-00250AT) and remove it from the Samsung mounting. There is a black 'flag' on the motor body that tells the TV where the colour wheel is. This is different on the sagem but you can just peel it off and draw a mark with a permanent marker pen in the same position as the old unit. I've replaced mine on HD-D45 recently. Works perfectly
Mar 12, 2008 | Televison & Video
Looks like pen marks on inside of screen
What you are decsribing sounds like your picture tube or tubes have been scored (permanent burn marks on the picture tube phosphor). The sure way to tell is to remove the front screen and look into each of the three lenses while the set is on. You will see a black image of your pen mark within the picture. Did you recently have problems with convergence or the set shutting down (turing off by itself for no resaon) ?
Nov 12, 2007 | Toshiba 50H82 50" Rear Projection...
Black Marks on T.V.
service call to determine if it a convergence fault or something alse.
Sep 09, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
LG Flatron L1710B 17" LCD Monitor Logo
146 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
