Question about Aprilaire 600 Humidifier
Solenoid on Aprilaire 600
Last year I replaced a solenoid on my father's humidifier. Now both solenoids indicate they are not working (power and water-no flow). Is he doing something to the controls to burn out the solenoids?
  • peters15612 Jan 13, 2009
    Since my question I have found both Solenoids clogged (only one year).
  • Stephen Evans May 11, 2010
    Are you sure the solenoids are bad and not the Humidistat
Solenoid valves dont just burn up just like that you have a recurring restriction due to bad water.Check the saddle valve at the water heater first then check for postive water flow at inlet to the solenoid valve,if you have water flow the valve is clogged with sediment.
Posted on Jan 13, 2009
Water to humidifer won't turn on.
Check if there is power to the solenoid valve, if ther is , then the solenoid is bad and must be replaced. If there is no power could be a bad humidistat or transformer.
Dec 19, 2012 | Aprilaire 600 Humidifier
Aprilaire 550 not turning on
Hello, apply power directly from transformer to solenoid valve, it it does not turn on the solenoid valve must be replaced. If there is no voltage to the solenoid then follow the wires back and see where there is no voltage.
Nov 18, 2011 | Aprilaire 550 Humidifier
Our humidifier is not kicking in and operating. after inspecting the filter which i changed out last August, it does not look like it has been operating at all and the house has been dry. I loosed the...
Hello, if you have 24 volts to the solenoid and the valve does not click open then it must be replaced. Also you can aplly power directly to the solenoid from the transformer and see if it will click open to let the water thru. either way looks like you solenoid is bad.
Mar 05, 2011 | Aprilaire 600 Humidifier
Humdifier not working after replacing filter. Have replaced before without a problem. It has been installed for over 6 years.
Hello, check to see if you are getting 24 volts to the solenoid valve. if you are and the solenoid does not open to let water through the solenoid is bad and must be replaced. It is also possible that one of the low voltage wires may of came loose when you were changing the filter, check to make sure that the wires are all tight. Let me know what you find.
Feb 11, 2011 | Aprilaire 600 Humidifier
There is no water coming out, i have an aprilaire 600 model with a manual controler
The first thing you want to check is that the saddle valve is open and that water is getting to the solenoid. If you are getting water to the solenoid but it's not going through then most likely you are not getting power to the solenoid. When there is a call for heat you should be getting 24 volts to the solenoid and it will open allowing water into the humidifier, if you are not getting 24 volts then check the transformer make sure it is giving you 24 volts.
Dec 18, 2010 | Aprilaire 600 Humidifier
We just bought a house with an existing Aprilaire 600 humidifier. It is now heating season and we ae running the furnace. I turned on the humidifier and no water is getting to the pad.The water line is ok...
Hello,Make sure the heating blower/fan is running when you turn the dial as the humidifier might not have power if there is no heating blower operation.
Nov 06, 2010 | Aprilaire 600 Humidifier
Solenoid valve won't open
Check for 24v.hum transformer shuold interlock/power up during blower motor hearing speed operation.Make sure its running.also manual mode resistor has to be installed in control panel.a blue plastic tag w/2 ends.
Mar 15, 2010 | Aprilaire 600 Humidifier
Aprilaire 600 problem
It sounds like you got it...
The solenoid will not open with only 13 volts to it. Jump or apply the full 24-27 volts to the solenoid and see if it clicks and opens and allows water to flow.
If the valve still won't open or pass water, start looking for a plugged inlet solenoid inlet screen or a faulty solenoid valve as well as a faulty humidistat.
Jan 06, 2010 | Aprilaire 600 Humidifier
Aprilaire Model 560bone dry, water is on, what can I check?
Yes, just check to see if you have 24 volts going into the solenoid. If you do and it is not opening its probably bad. Since you verified the water lines, filter, orifice and saddle valves are not obstructed. Change the solenoid valve. When you price the part. (it's not cheap) consider paying about 30% more and just change the whole unit.
Good luk
HVAC Teacher
Feb 18, 2009 | Aprilaire 600 Humidifier
No water at all
does the solenoid click when in test mode, if not check power to panel/solenoid.
If it does check that restrictor is not blocked
Jan 19, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
574 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
