Question about Brother MFC-8460N All-In-One Printer
MFC-8460N is smearing 3 small 1/2 circle size blotches of ink on the left edge of the page, evenly spaced down the page.
    President:
  • Brother Master
  • 990 Answers
If these 3 blotches line up in same track ,then you have to change you drum unit.
Posted on Dec 13, 2008
My brother mfc 7440N prints splotches every 3-3.5" on every page printed. This occurred with the previous and new toner cartridges. How to fix?
For crying out loud.
The "blotch" is caused by damage to the drum or to the toner fusing roller.
If the "blotch" is loose toner (in other words you can smear it) then the fuser roller is damaged and that assembly needs to be replaced.
If the "blotch" is fused (in other words you cannot smear it around) then the drum is damaged and that assembly needs to be replaced.
The original MSRP for the Brother MFC-7440n in 2008 was $429 (US) / 213 pounds [FixYa couldn't handle the pound sign!! =8-) ] (UK) / $499 (AU). The present street value is about $199 according to Brother ( http://www.brother-usa.com/MFC/ModelCompare/4/MFC7440N_MFC7460DN#.UXBKKKLq3yA ).
A drum unit is $80 (Amazon) or $115 (Staples).
That same $200 could get you a Canon Pixma MX-922 (Canon http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx922). Inkjet? Yes. But fast. Airprint. 2-sided ADF and copying. Auto-duplexing. CD/DVD disc printing. Frankly, if I didn't already have an Epson 835, I would buy this one. My old Canon 820 still chugs along as beautifully as the day I got it (about a zillion years ago).
For $50 more you can get a top-rated laser, their imageCLASS MF4880dw (though oddly, without Airprint - for Airprint in a Canon laser, you have to step up to the big boy: the imageCLASS MF8580Cdw).
Well. Have fun!
Mar 31, 2013 | Brother MFC-7440N Laser Printer
There are black ink blotches when I try to feed envelopes through the rear feeder
use the maintance function on your printer to adjust the ink output level.
Dec 21, 2012 | Brother New-MFCJ6710DW - MFC-J6710DW...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The printed pages have pink blotches on the right hand side of the paper and horizontal pink blotches down the page
Try cleaning the color or magenta cartridge with rubbing alcohol and look inside the printer to see if there's pooled ink anywhere that is smearing on the paper. Try replacing the print head or cartridge.
Sep 17, 2009 | Lexmark Office Equipment & Supplies
Vertical line on Brothe MFC 8460N
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 22, 2009 | Brother MFC-8640D Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Brother MFC-8460N All-In-One Printer Logo
171 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
