Question about Lexmark X73 All-In-One InkJet Printer
I can't get my printer to work at all.
The message I get is it is not compatible to Windows XP
  • zoly_13 Feb 13, 2009
    Am cumparat multifunctionala LEXMARK X73dar nu mi-a trimis si CD-ul cu driverele,doar niste linkuricu ghiduri de utilizare in limba engleza ,din care nu prea inteleg totul.Am copiat linkurile respective dar nu pot printa si nu stiu ce sa fac.
  • 827 Answers
Here is the lexmark printer x73 driver 1.0.17.2
http://printers.free-driver-download.com/Lexmark/12559/Lexmark-Printer-X73-Driver-1.0.17.2-WinXP.html
first go to control panel > system > device manager and find the printer device. double click it then uninstall whatever device is being used. then run the new driver in the download.
you can download and unpack the downloaded file, and then go back to the control panel and let the device manager 'find' the driver, or you can install it manually. (the downloaded driver may come in an .exe form which should install from there)
good luck
chris
Posted on Dec 13, 2008
How can I fix a Win32 error message on my LabelWriter 450 printer. Was working b-4 on windows x-p. Can't get it to work on Windows 10 !!!!!!!!help
chances is it is not compatible with Windows 10! If you have another computer running windows xp or vista hook the label writer to it, if it works then compatibility with with windows 10 is the problem, unless they have an software update for your printer, it wont work.
Feb 10, 2016 | Dymo ® LabelWriter® 450 Series PC...
Yearplanner 64 bit
The old program may not be compatible with Win 7, so try running in Compatibility Mode.
To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP,
and then, under See Also in the navigation pane, click Program Compatibility Wizard.
Feb 25, 2014 | Office Equipment & Supplies
I purchased a new computer w/windows premium7. Old computer was XP. The Brother multipurpose worked well with XP machine. With new machine, though, it performs all functions well, except for OCR. When I...
Did you checked if your printer is compatible with windows 7?
Here go to this site to check if your model is one of the compatible to windows 7
http://www.brother-usa.com/lp/windows7compatibility.aspx
if you find your printer there and it is compatible with windows 7 you can download the driver in the BROTHER SOLUTION CENTER column on that webpage/
Goodluck, Hope I hep. Please rate my solution thanks.
Jun 30, 2011 | Brother Office Equipment & Supplies
Trying to install software for all-in-one-printer Kodak ESP C310 and am receiving message that software has not passed Window Logo testing to verify its compatibility with Windows XP.
software has not passed Window Logo testing is a known microsoft windows xp issue .disregard the message and click on continue anyway until you get to finish the installation.if it keeps on popping up,keep on selecting continue anyway.
Jun 11, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have installed Adobe Acrobat 7 on my laptop that runs on Win 7 platform. However, the installation of Acrobat flashed a warning message that Adobe Acrobat 7 was unable to create a new item: Adobe PDF...
Good Afternoon -
Direct from Adobe, they state that versions 9 and above are compatible with Windows 7, and any versions 8 or prior are not supported and updates to make compatible will not be released. There are two solutions, one that may work and one that will definitely work. The first is to try to install the program under Windows XP compatibilty, natively on Windows 7. To do this, find the executable for installation, right click and select properties. On the comptability tab, click the check box that says: Run this program in compatibility mode for: and select Windows XP (Service Pack #) from the drop down, and proceed to install, running the installer as Administrator. The other guaranteed way is if you have Windows 7 , any version other than starter, you can enable Windows XP Mode which creates a virtual PC of XP on your machine and integrates the program references into Windows 7. Details on this can be found:
http://www.microsoft.com/windows/virtual-pc/download.aspx
Please feel free to contact me with any questions.
Apr 09, 2011 | Adobe Acrobat 7.0 for PC
Is xerox work centre 385 comparable with windows xp?
Yes this printer is compatible with Windows XP, you can download the driver for this printer from this link to work with XP , just click HERE and you need the driver for it.
Oct 31, 2010 | Xerox WorkCentre 385 Laser Printer
Is the Dell A940 compatible with imac computers?
Hello there!
As i know dell printers dont offer you ability to use them with mac computers, but i know that you could use your printer as a server from some windows os pc, and connect it with your imac computer, if you are able to do that here you go, detail instruction will be provided for you in next text lines.
This document gives a detailed explanation of how to set up an HP DeskJet 722C printer that is attached to a Windows XP computer so that the printer can be used by a Mac OS X computer on a local area network (LAN). If your printer is slightly different, or you have a different version of Windows, or you're using a different Unix than Mac OS X, you'll have to adapt these instructions with your own creativity.
Be aware that these procedures may not be necessary at all if the printer you have has Mac drivers, and other Microsoft incantations are working properly. You may be able to get off easy, but then, you probably wouldn't be searching the Internet looking for these instructions. Your mileage may vary.
Thanks to the detailed directions at http://pnm2ppa.sourceforge.net/PPA_networking/PPA_networking-4.html which gave me most of the information I needed to make these detailed instructions.
The process falls into these five general steps:
  1. On Windows: Make sure you have a working printer set up on your Windows XP computer (this is not covered here).
  2. On Windows: Install the software needed to emulate a Postscript printer and redirect printing ports
  3. On Windows: Set up an emulated Postscript printer on Windows XP that will actually print to the (probably non-Postscript) printer set up in step one.
  4. On Windows: Set up Unix LPR Printer Services on Windows XP that will point to the emulated Postscript printer in step three that in turn points to the real printer in step one.
  5. On Mac OS X: Set up an LPR over IP printer in Mac OS X pointing to your Windows XP computer.
What follows are some email messages that people have sent me about some problem they overcame that I did not encounter. I'm sorry I cannot "boil down" their advice, because I no longer have a PC, but here is what they have to say.
Apr 17, 2010 | Dell 942 All-In-One InkJet Printer
How can i install on windows xp
Yes, you need the driver for windows XP. go to here
May 30, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Trying to install HP Deskjet 712c on computer with windows xp
You shouldn't need any software to print to this printer under XP, just let XP find the best or closest match to your printer and install it. It might be a Deskjet 700 or something but it'll work as a printer. The old software was probably for Windows 98.
May 28, 2009 | HP DeskJet 712c InkJet Printer
I just purchased windows vista home premium and have a lexmark X6100 all-in-one printer. It says it's compatible with windows XP. I can't run it but was able to install it. I tried to uninstall it and...
Soultion, Don't run vista, no really, acully try running it as compatability as Windows xP, right click the file, properties, choose the compadabiity tab, then choose run as Windows XP and also try to choose the run as administrator.
Apr 14, 2008 | Office Equipment & Supplies
Lexmark X73 All-In-One InkJet Printer Logo
293 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
