Question about Dynex 19 in. LCD Flat-Panel HDTV
Unable to access main menu 20` rOUND tUBE tv
When I push MENU I get several lines of AV2s. How do I get to the main menu?
  • alfono Dec 13, 2008
    This problem occured as I was attempting to set up stations.
  • 36 Answers
Dear Customer
Please undergo the following
Sir/Madam i can help u by giving a link in which you can directly ask customer service about this problem which would make feel convenient .and the link isgiven below
http://www.northjerseymall.com/Mall/CommonPages/customerservice.asp
Please rate this,Thank u
Posted on Dec 17, 2008
  • 734 Answers
Please discribe your problem in detail.
Thanks
Posted on Dec 13, 2008
  • 10,594 Answers
Please mention exact model and brand of tv to look for technical info for its problem.
  • 13,433 Answers
Unplug the Tv for 5 minutes and try again, what do you actually get? AV2 all over the screen? that doesn't sound good.
  • Ekse Dec 13, 2008
    Can you tell us more of the problem? I'm not completely sure whats happening.
  • Ekse Dec 13, 2008
    The user manual is available for download from
    http://www.dynexproducts.com/p-604-dynex...
    For your DX-LCDTV19 Model Television
    Push the menu button the menu button is below the menu text not above. That will open the on screen menu. The button above menu is used to select a digital sub-channel.
Apex Tube tv
check your screen menu and check screen size should say normal, wide screen and cneima . change to a smaller screen should bring everything in line
Feb 08, 2013 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Unable to switch from tv to cable Magnavox older 13
Have you tried accessing the on screen menu and maybe changing the input type to cable or even line in if you are using rca (red/white/yellow) plugs to connect the cable box to the television?
Oct 19, 2012 | Philips Magnavox 20MT133S 20" TV
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Noticed that all of a sudden i can't get channels past 20 and i have several other tvs in house on same cable line (without box) that get 99 channels
you need to access the menu in the remote control and go to add/delete channels and this should open up the channels
Nov 14, 2009 | RCA TruFlat 27F520T 27" TV
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Unable to turn CC off
the captions are on in the dvr cable box. you cable guy can emter the menu on the box and turn it off. Some boxes will allow you access by pushing the power button on the box while tv is on then immediately pushing the menu button but be careful.
Jan 08, 2009 | LG 37LP1D 37 in. LCD Television
Remote Difficulty
Looks like you are in trouble mate.you may have to buy origional remote.there are certain programmable remotes out there which give every function of the origional.most service centers have them,they have to be programmed by computer to suit each individual set.
May 16, 2007 | Pioneer PRO-1009W 57" Rear Projection...
Sorry about spelling - new TV buttons are locked and can't unlock parental control menu to unlock
tray with this code to enter in parental control: TV = 0358 or 5898. DVD = 1389 or 9922.
Dec 21, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Parental Control Locked
for an unknown passwrod try, go to parental control in menu then push mute,pisplay,clear,reset buttons in sequence. you may need to borrow a friends remote to do this. once in you can change your setting. good luck
Nov 12, 2006 | GE 19GT317 19" TV
Dynex 19 in. LCD Flat-Panel HDTV Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
