Apple MacBook PC Notebook Logo
Alfred Cato Posted on Oct 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Mac that I've had for almost a year refuses to take any disks into the drive. I think it may be related to strange sounds coming from the drive everytime I open my Mac. Any suggestions beyond w
Bill Boyd
Level 3:
Top Expert:
  • Apple Master 53,816 Answers
  • Posted on Oct 30, 2017
Bill Boyd
Apple Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950053
Points
172802
Replace the cd unit to fix the fault
the cost will be a new unit plus 1 hour labour charges so get quotes from different computer shops
5 Related Answers
Anonymous
  • 20 Answers
  • Posted on Jun 10, 2008
SOURCE: Macbook won't accept CD's/DVD's in Disk Drive
do you usually lean or put any pressure on the area above the slot-load optical drive? If you have anything flat and plastic around 1/4" (about 1/2 the width as a USB plug) stick it in the optical drive until you just feel it going past the door, and rotate 90 degrees so it opens it a little. See attached photos if you aren't sure what I am talking about7804560.jpg
Anonymous
  • 186 Answers
  • Posted on Jun 20, 2008
SOURCE: Open case of Apple Powerbook G3
Several screws on bottom and the whole top case snaps off. It will take a little time on this model to gently pry. Also, I think the keyboard comes off first before removing the top cover by two finger pegs. It's been a long time since I worked on this model you you'll just have to get in and look around. Very common on this design that the power plug just needs re-soldered to the motherboard.
MacApplePi
Martin Buck
  • 86 Answers
  • Posted on May 29, 2009
SOURCE: optical disc drive malfunction
The optical drive checks the TOC (Table Of Contents) when you insert a disk. If it can't read it, (for any reason), it will eject the disk. This may be due to a dirty laser, or that the laser has failed.
Try using a laser cleaning disk, (these are available from most high street retailers0. If that does'nt cure the problem you will have to get the drive replaced.
Farzin
  • 25 Answers
  • Posted on Jul 10, 2009
SOURCE: how to format an apple power G4 notebook
When the computer is off, press the C in your keyboard then turn on your computer. After that computer will boot from CD.
Regards.
Anonymous
  • 1383 Answers
  • Posted on Jul 24, 2009
SOURCE: apple mac book : how to enter the bios setup
When you power up the computer press F2 or "del" or F5 or F12 or TAB key to enter in bios.
Thanks for using fixya.
Please rate this solution if it helps you.
1helpful
Mac cant find the hard drive
Clicking Hard drive When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
NEW MacBookPro crashes! I just bought a new macbookPro and it has crashed on three different programs; won't download the manual from online (get the beach ball) and makes a sound when power-ing u
The two "whirring" noises that you hear on power up is normal. The beauty of having a new macbook is you can reinstall the software very easily and a fresh install should fix your problem. Put the disk that came with the machine into the disk drive and turn the computer off. Turn it back on and press and HOLD the "alt" button until you are given the option of booting from your hard drive or your disk. Choose the disk and when it boots up, FIRST go to disk utility and verify the hard drive. If it comes back with no problems, proceed with the fresh install of the system by following the prompts on the disk.
1helpful
MY MAC SAYS MAC OS XSET UP DISK IS FULL WHAT DO I DO
Yeah...sounds like your hard drive is full. One thing that a lot of newer users do is keep the .dmg, .sit and .zip files after they've installed new programs. So double check that you've properly installed any new programs into your Applications folder and then trash those .dmg, .sit. and .zip files (if you have any).
Tell us more about your system, how big is the hard drive. Do you have a lot of Music, Photos or Movies files you've got on there. If you do, you need to start looking for an external storage option for some of those files.
FYI, you should keep a pretty good sized portion of your hard drive free for the system to use as virtual memory storage...if you don't, it will slow down your system.
BMW ACCECSSORIES
Internal HD accidentally deleted
Hi, Run System Profiler. It's in the utilities folder along with Disk Utility,
Have a look at the ATA bus. Does it list both disks or just your start-up disk and the DVD-drive?
If your second disk is not showing here then it may well have died. Even if it does show it may still be dead and the only way to make sure is to use a stronger tool than Disk Utility.
Unfortunately you may have to buy that and it's cost is not far short of the cost of a new drive.
I've known apparently dead disks come to life after a short spell in a freezer inside a sealed plastic bag. Unfortunatley they rarely stay alive for long - just long enough to copy important files!
2helpful
Monitor drops into sleep at random; power light amber; hard drive light green; disc drive light comes on green
Try another monitor and see if it acts the same way. Borrow a monitor from the next door neighbor for an hour or so or from a relative and see if it behaves the same way. If not, go purchase a monitor.
I have a mac and a new iogmega external drive, 500g. I cannot move any files onto the iomega or save them. I get messages such as "that file does not exist" to iomega can't be modified,...
With the drive plugged in, going into your Applications ' Utilities ' Disk Utility Select the drive and press Verify Disk, Repair Disk and Repair Permissions. If you don't have anything on the drive right now, try formatting it with the Mac OS Extended (Journaled) file system from the Disk Utility.
If that doesn't work the drive may be damaged. If you have another PC / Mac, trying plugging it in and see if it works there. If the drive is under 1 year old it should still be under warrantee, in which you could return it / RMA and get a new one sent back from the manufacture.
Regards, Chris
1helpful
Strange clicking sound from my book home edition 1TB. Disk is not visible in any system Mac or Windows.
Is the clicking sound continous? Did the disk fell down or did something else hit the dis? The symptoms are bad for the data you have in the disk... If the sound isn't constantly, leave the disk on the computer for a long time, it's possible to work again....
Stelios.
116helpful
8answers
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
