Wires at ignition
The 5 ignition wires of my nissan micra 91 have been pulled off and I need to know what goes where. (car broken into) can you help please
Problem is solved. I refit new connecting spades to the wires and guessed where the wires might fit. after three attempts i had the correct positions. thanks anyhow, mark
Posted on Dec 14, 2008
Nissan micra battry turminal is broken car w'not start help me
If the terminal is broken on the battery, you need a new battery. They are full of acid which will leak out. Very dangerous!
If the terminal is broken on the wire lead, you either need a new lead or a clamp on terminal like these.
https://www.bing.com/images/search?q=clamp+on+battery+terminal&FORM=HDRSC2
Go to Bing homepage
Jul 31, 2016 | Nissan Micra Cars & Trucks
Nissan micra bonnet won't open
check that the cable did not jump out behind the lever. also ,some cars have electric/ semi electric systems where you need to switch on the key to open the bonnet or the bonnet has a fuse which could be blown. check fuses.
Apr 09, 2014 | 2010 Nissan Micra 1.2
I HAVE A 2005 NISSAN MICRA ESSENZA CAR,,,,, when
this one will work. http://www.ebay.co.uk/itm/2003-Nissan-Micra-Electronic-Accelerator-Pedal-/321195223272?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ac8ba28e8 dont know if you are in the uk
Oct 07, 2013 | Nissan Micra Cars & Trucks
Blower heater unit in micra k12
hi did you get the resistor fixed if not you need to remove the glove box by removing the screws that can be seen then there are two plastic lugs that need to be pulled out sideways to enable you to remove the glove box then you will see the resistor card on the side of the motor thats on the new shape micra k12
Mar 03, 2010 | 2006 Nissan Z
Headlights go on and off while driving
there might be a prblem with the sensors on your dash or a shor t in the wiring to the headlights
Aug 01, 2009 | 2000 Ford Focus
I'm replacing the ignition control module in an 83 280ZX turbo. There is a blue wire and a black wire w/white stripe. Which goes to positive and negative on the coil?
The black wire goes to the positive terminal and blue goes to the negative terminal.
Is your car running?
There is a procedure in the factory service manual: http://www.xenons130.com/reference.html
Hope this helps!
Todd in Idaho
flying.coyote@hotmail.com
'69 510
'83 280ZXT
'91 300ZXTT
Jun 25, 2009 | 1983 Nissan 280ZX
Battery dead and can not get into micra
HI, WHAT YOU NEED TO DO IS JACK THE FRONT OF THE CAR UP GET A SET OF JUMP LEADS AND A BATTERY OR A NEIGHBOURS CAR AND CLAMP THE RED LEAD ON TO THE STARTER FEED CABLE, (THICK WIRE) THEN CLAMP THE BLACK LEAD TO EARTH, THIS SHOULD ENABLE YOU TO ACCESS THE CAR, HOPE THIS HELPS
Mar 01, 2009 | 1997 Nissan 200SX
73 people viewed this question
 Grubhead
Grubhead
