Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
H20 my machine has h20 on the lcd panel but the water is ok and the machine just fillls until it floods out and doesn't go through programme all the time i've h20 flashing how can i reset or solve this cheers
I had same prob with this model took it to bits filters (found 80p) but its the round falve under the fabric conditioner draw there is a clear pipe on it and thats come off. try it push fit so its simple take about 6 mins start to finish. all the best
Posted on Mar 09, 2009
  • Hotpoint Master
  • 3,463 Answers
According to the Hotpoint error code list H20 indicates to check taps and pressure of incoming water..
So make sure you have adequate pressure of water at the valves, low hot water pressure can cause problems..
Also what I would do would be to check the filter located in the sump hose at the rear of the m/c,\this can leade to a sticking water level s/w..
Hope this helps.
Plz leave feedback.
Thanks.
Posted on Dec 13, 2008
My aqualitis aqxxf149pi is displaying h20 error code, filling correctly at start of wash cycle but mid cycle starting to add excessive water before it goes on drain and spin resulting in flooding
H20 is a water warning. The machine THINKS it has no water coming in (Hence it continues to fill and fill because it can''t see the water). 99% of the time, this is a blocked rubber pipe that goes to the pressure sensor. Water in the drum fills the bottom of the rubber pipe and as the water rises, the air pressure in the pipe increases, which operates a bellows device in the pressure sensor. If the pipe is blocked, the pressure sensor won't operate and it will continue to try to fill until it times out. There COULD be a wire off the sensor or a wire that goes to the sensor loose on the main board, there could even be a failed component on the main board, but all of these scenarios are ar less likely than a blocked pressure sensor pipe. Take the lid off, pull the pipe off the bottom of the sensor, blow down it hard and this may well clear the blockage. Put the pipe back on the sensor and test. Come back if you need more advice
Aug 24, 2015 | Hotpoint Washing Machines
Just keeps filling at the start of program and displays H20
Your washer has a bad water valve or fill censor telling machine need more water then to much water sends a flood warning shuts down so will not flood your home look for small clear tube coming from tub to a type control hose may just came off
Mar 09, 2015 | Hotpoint Ultima WF860 Front Load Washer
Display periodically flashes H20
The faulot is related to the incoming water supply.
Chaek inlet hose for restriction or low water pressure.
Jan 19, 2010 | Washing Machines
H20 error
Hello
I used to get this when i lived with my mum & dad and i can honestly say that it was the water pressure with this machine only a small drop in pressure makes the H20 error code appear you can always add additional water when it comes on so that the cycle can continue. You could find out from your water board if the drop in pressure is a leak in your area?
I hope this helps i had to persist with this problem for 18 months untill a leak around the corner was eventually found and fixed.
Regards
Wendy
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
H20 f-08
the machine is sensing a flood you need to get it dryed out remove the front panel and dry out the bottom plate then press pause/cancel twice to clear Fault
May 28, 2008 | Hotpoint WF645 Front Load Washer
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Feb 19, 2008 | Hotpoint WMA50 Front Load Washer
Water overflow
Are you on a well? Often people with a lot of sediment in water get sick of the screens in water valve plugging up so they remove them. NEVER remove these screens. If any sediment gets into valve it can hold it open causing flooding. If you unplug unit and water still comes in you must replace valve.
Oct 08, 2007 | Maytag LSE7806A Top Load Stacked...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
543 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
