The blades on my Bamix Mono will not slide down all the way on the shaft. The notch won't slide down onto the pin. Even when pushed down only partway, it is almost impossible to remove the blade. What is the problem?The blades on my Bamix Mono will not slide down all the way on the shaft. The notch won't slide down onto the pin. Even when pushed down only partway, it is almost impossible to remove the blade. What is the problem?
You can't post conmments that contain an email address.
Re: I can't remove the blade from my Bamix hand blender
Shaft should be free for rotation that is ok. Blade will come off with determined force of pull make sure grasp blade with towel to prevent injury to the fingers.
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine.... They sell many accessories and you can get blades. Check: www.bamix.com www.bamix-blender.co.uk I have both machines and the blades are identical and inter-changeable between models.
click on the "contact" link in this website http://www.bamix-usa.com/ there's places in Canada & the US to have them serviced. Through contacting them they'll give you the nearest service area.
Good luck, love my Bamix!
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
The blades pull straight off the shaft. If you look closely you will see a small notch on the blade that fits a tab on the shaft. This keeps the blade turning at the same speed as the shaft.
Anyway, pulling straight down on the blade should get it off. You might try boiling the tip in water to soften whatever gunk is holding it on. Be careful you don't burn your fingers when trying to pull off the blade after boiling it.
