Question about Sony SLV-ED85 VCR
Video tape ejects itself
I have a brand new E-240 tape. When I try to load it, the machine takes it in, whirrs then after about three seconds, ejects the tape again. The machine works fine with an old E-240 tape. The VCR is a Sony SLV-EZ735 (which your website didn't recognise). It's three years old. Hope you can help, Cheers, RebeccaB
  • Rebecca Brierton Mar 16, 2007
    Thanks for the tip, but it's a brand new tape and yes,the tab is still in place. Appreciate the thought though.
  • 53 Answers
Not to overlook the obvious but check to make sure the record safe tab is still on the tape. (little black tab on lower left corner on back of tape)if tab is gone the machine will not go into record mode.
Posted on Mar 13, 2007
HOW DOES THE TAPE CARRIAGE EJECT AND LOAD?
go to mcmelectronics.com and order the replacement belt kit. then google your model number on alignment pdf. Your mechanism is out of alignment due to bad belts
Dec 03, 2017 | Televison & Video
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
Magnavox vcr/dvr. insert vc tape, machine loads and plays tape for about three seconds then stops and ejects tape. tape will not stay playing. thanks, larry
Mine does the same.It's basically junk.A new VCR/DVD player goes for around $80.If you were to call to ask about getting your VCR repaired,they would tell you that it is FAR cheaper to simply purchase a new one.Same Magnavox I bet almost too.model # for mine is MWD 2206.Labor alone is easily at least $60/hour and it would take that just to disassemble and reassemble the VCR section just to get at the problem.Greg
Feb 10, 2011 | Televison & Video
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
Tape mechanism
This sounds bizarre I know, but I read another threat regarding Canon camcorders and tapes self ejecting. The advice was to ........ wait for it........ drop it onto a carpet floor from about 1/2m. My wife top me not to consider it. I continued reading and someone else had been successful using the technique. I have to report that it actually works. I dropped it (twice for good measure) and it loads tapes once again. Its true what they say, if in doubt....give it a clout!!!
Mar 19, 2008 | Canon MV750i Mini DV Digital Camcorder
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
Sylvania SRD4900 DVD/VCR combo problem
There's a problem with the tape drive, so it's shutting down to prevent damage to the tape. Someone familiar with VCR mechanisms would probably have to see it in action to identify what's wrong. Most of them act in a similar fashion, so if you have a working VCR, you can take the cover off and watch it load a tape, run it, rewind and eject, then compare with the non-working unit. The parts won't be interchangeable, but the tape loading will look much the same. You can comment on what happens and I can try to explain what I think is going on. Better yet, if you could post a video of the internal mechanism while it tries to load a tape, that would be very helpful.
Aug 05, 2017 | Durabrand DUR7 Portable DVD Player
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
May 01, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Sony SLV-ED85 VCR Logo
266 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
