Question about Inverter 220 Volt Tig Arc Welder
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
This is a new set. the fan comes on 15-20 seconds then stops power light stays on no arc at any time any help would be great .thanks Paul.
  • 25 Answers
Remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Posted on Jan 19, 2009
  • Larry
    Larry Feb 24, 2009
    Let me also state for the record that this man's machine, a Giant, is not one that we sell for we sell only GiantTech, two completely unassociated companies.
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
Kende weld no arc
make sure your work-piece has a proper ground. and maybe check your gas connection. no leaks. maybe turn gas down.
Mar 27, 2013 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
I have a champion 10000 watt gen welder won't bur
Make sure the switch for remote power or control at machine is on the right setting. It will arc but very faint if this switch is not on the right setting.
Mar 17, 2012 | Hobart Welding Tools
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
M lincoln 225 arc welder runsfan comes on but will not strike an arc in any switch settings on front of unit.has been welding fine except for a year it would not arc in a few of the settings and now none...
Transformer is burned out. Various windings are taken off at different points to alter the amount of power, they have eventually burned right through , So that is why some worked and some didn't It has now completely gone. The cost to replace the transformer may well exceed the cost of a new welder.
Please rate my help++++Thanks for using FIXYA
Jun 18, 2010 | Garden
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Giant inverter tig mma111 230 volt
check if the load on it is not more than its capacity and check the batteries if they are still in good condition
Nov 16, 2009 | Inverter 220 Volt Tig Arc Welder
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Inverter 220 Volt Tig Arc Welder Logo
2,750 people viewed this question
Top Inverter Welding Tools Experts
Robert Lee
Level 1 Expert
Tom Chichester
Bud H
Are you an Inverter Welding Tool Expert? Answer questions, earn points and help others
