Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Bosch kvg28323gb fridgefreezer
Is there anything i can do to stop my freezer door from suctioning so tightly when i open the door the freezer door sucks itself shut you can see it do it and very hard to open i tried putting washing up liquid on the seal but dident do anything
  • 3,866 Answers
Well, there made to seal to keep the air in. Did you try a little DW 40?
Posted on Apr 21, 2009
How tight should the suction be on the door of chest freezer
Hello dotty26 - The door gasket should be securely closing with no resistance. You may try lubricating the door gasket with petroleum jelly to make it easier to open as well.
Feb 25, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
Side by side kenmore refrigerator no suction on produce side
There is no suction normally. The door has a spring type mechanism to keep it firmly closed, and the magnetic seal takes up the slack. Check the door/ hinge is straight and tight and look at the top of the hinge. There is a small cylinder about 5mm high with a number of dimples in it. One of these should have a pin in it that operates the spring mechanism; if it is missing the door will not close well.
Also make sure there is nothing in the fridge protruding, stopping the door from closing and the seal sticking!
Apr 18, 2012 | Kenmore Refrigerators
Why does my fridge not work on my fridgefreezer and my freezer does
HI Dean,
All the cold air is generated in the freezer and pushed to the refer side by a fan. With that being said, with an obstructed air channel the refer suffers. So you will need to determine how the air flow is obstructed. Do you have ice on the back wall of the freezer? If so, defrost could be the problem, if not, has the units door been left open? If so, you will need to remove the air flow restriction. To further help you, I need a model number, and answers to the questions above to understand what you see so I can direct you in the right direction and repair.Good Luck
Dec 02, 2011 | Refrigerators
Bosch side by side isnt freezing
call a repair service locally , but with what you tell us , it may be too late for a fix
Oct 09, 2017 | Bosch Evolution® 500 B20CS50SNW Side by...
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Firdge freezer
This is caused by one of several things:
  • door left open
  • bad gasket
  • open liquids in fridge
  • dirty condenser radiator...clean it
  • low gas in refrigerant system
Defrost the unit completely and restart. If it happens again, suspect the last and get a service person in.
May 27, 2008 | Freezers
Servis fridgefreezer light
IT COULD BE A BAD LIGHT SWITCH, SOCKET OR BULB.
IF THE CONTROL IS ELECTRONIC, SOME REFRIGERATORS WILL SHUT DOWN THE LIGHTS IF THE DOOR IS LEFT OPEN TOO LONG.
BE SURE THE BULB IS SCREWED IN ALL THE WAY. SOMETIMES, THEY WILL WORK LOOSE.
Apr 02, 2008 | Freezers
HOTPOINT FRIDGEFREEZER
Sounds like frosting up. Defrost completely...that can take 2 days. Restart. Also, clean the condenser. Check door gaskets, clean and replace as necessary. Don't keep door open longer than necessary.
Dec 20, 2007 | Refrigerators
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
413 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
