Question about JVC HD-61G787 61" Television
JVC HD-61G787 IR receiver location
I need to know the lacation of the IR receiver and the best way to get to it. I know it is behind the screen. I have to control the tv with an IR emitter that has to be attached directly on top of the receiver
I took the front of the tv off. the IR receiver is beside the lens. I stuck the IR emitter directly on the receiver and reinforced it with hot glue and then fed the cable out through the back off the tv. Not a hard job just lots of screws.
Posted on Dec 14, 2008
How do I remove the screen from a JVC HD-61G787?
May I ask why you need to remove the screen? There are a lot of screws around the back and along the bottom of the front after the speaker grill is removed. you will have to unplug the control panel before you remove the screen assembly....tks
Nov 04, 2013 | JVC HD-61G787 61" Television
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
Apr 22, 2010 | JVC Televison & Video
Look in the manual under "resetting the lamp timer"
This must be done with most any replacement
Browse to:
On that page is the (lower) is the exact procedure on resetting the lamp timer. You can also down the entire manual in PDF format.
Jan 15, 2010 | JVC HD-61G787 61" Television
Is there a way to clean the inside of the front screen?
Not without removing most of the chassis. I am wondering if what you think is dirt is actually screen deterioration. One has to be carefull cleaning even the outside of the screen, except with a damp and then dry soft cloth. The inside of the screen is even more delicate and any pressure can rupture it easily and replacement is astronomical
pleae rate my help++++Thanks for using FIXYA
Nov 25, 2009 | JVC HD-61G787 61" Television
Jvc HD 61G787 I replace the lamp and the ballast and still don't come on All the fans are working and after a few seconds stops
The main power supply of the set may be faulty, and or there is a fault condition on one of the other boards, and the main power supply is going in to protect mode.
Jerry G.
Sep 26, 2009 | JVC HD-61Z786 61" Rear Projection HDTV
The part # is 61SC-006A-M2 with a cost of around $439.99 with free shipping.This will include all 3 screens. 1-866-925-PART (7278)
Jan 15, 2009 | JVC HD-61G787 61" Television
My screen has shadow spots that look to be on the inside of the
you may be able to clean the lenses but if that dosent work it usually means its there for good
Jan 02, 2009 | JVC HD-61G787 61" Television
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
Hope this helps
Aug 10, 2008 | JVC HD-61Z456 Television
JVC HD-61G787 61" Television Logo
307 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
