If a computer reboot's always, what is the cause
Virus
Posted on Dec 13, 2008
Who do you reboot?
I couldn't read the information on the screen.
If you need to reboot, there sometimes a reboot button. Pressing and releasing it will cause the computer to reboot.
If there isn't a reboot button, press and hold the power button until the computer turns off. Release the button and press and release it to reboot the computer.
Good luck.
Paul
Feb 17, 2016 | Computers & Internet
Device driver codec 28
Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your bios. If that's the case, a reboot might fix the Code 28.
You might have to visit your computer or hardware manufactures homepage and download the driver for the device.
Good luck
Nov 01, 2012 | Computers & Internet
I have 1 friends page that always causes my computer to freeze before it fully loads? I have windows XP, I have rebooted, doesn't help. All my other friends pages on FB work fine?
Try downloading the latest updates to Macromedia Flash player, and Java. Does your friend hava a lot of moving graphics on the page?
Bob
Aug 15, 2010 | Microsoft Windows XP Home Edition
I need a driver software of microsoft isatap adapter #3
do one thing -- open DEVICE MANAGER--> and uninstall the adapter ,then REBOOT .....
Nothing else to do, Windows will do the rest. And you can ignore the errors altogether if you wish and on some computers it will always be there but cause no problems.. also refer : http://support.microsoft.com/kb/932520
Feb 10, 2010 | Microsoft Windows Vista Ultimate Edition
How do I reboot vista laptop in order to remove radial point
a reboot is always a last resort!!! a better option to remove a program is to access control manager by pressing ctrl, atl, delete at the same time. when the prompt window is opened look through both processes and services tabs for anything related to the program hit stop process then just go to start>control panel>add/remove program. if that doesnt work restart your computer in safe-mode. if its a vista hit the power button let it rest for a sec then restart it. since the computer was improperly shut down it will ask if you want to start windows normally. don't instead choose start in safe-mode when it starts everything related to radial point will be shut down making it easy to remove the program through control panel. if you still whish to reboot shut down your computer by opening the start menu and in the lower right corner select restart. when the comp. restarts and the logo appears hit f8 quickly (you only have about 5 seconds before it restarts normally) choose boot with disk insert your start up disk and the computer will restart and all non-default programs will be lost. radial point will finally be defeated but at what cause? at what cause!!!??
Nov 14, 2009 | Microsoft Windows Vista Ultimate Edition
My computer reboots without warning while playing online videos or browsing the net. First it happens after working fine for some time and then it starts happening frequently. I have Windows XP media...
as my knowledge if the computer restarting by themselves always there are some error occured in this one area possibility :
1. error in software
2. error in hardware
3. error by virus infected
4. operating system issue
BUT :).. if u get this trouble after take some advennture in networld/network.. i suggest u computer ar sugessted with "blaster virus" the virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted. so the best way is update your security first
that is the first step
the second :i suggest u to run your computer in safe mode wait for several minutes if not reboot while running safe mode follow this step :
  1. From the desktop right-click on My Computer.
  2. Click the Properties option.
  3. In the System Properties window click the Advanced tab.
  4. In Advanced click the Settings button under Startup and Recovery.
  5. In the Startup and Recovery window uncheck the Automatically restart check box.
  6. Click Ok.
if still rebooting in safe mode there the issue is likely not software related but something else
the third :hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
  1. Reboot the computer and enter CMOS setup as the computer is booting. If you are not familiar with how to enter CMOS please read through document CH000192.
  2. After you have loaded the computer in CMOS setup let the com sit
hope u luck
Sep 27, 2009 | Office Equipment & Supplies
I have a Canon Pixma iP4200 printer which is causing my Acer Aspire T310-3970 PC to reboot when I turn the printer on. It keeps on rebooting until I switch the printer off. Any ideas?
If the computer does reebot immediately when you turn printer on, that is not aa software or setting problem , that is an hardware fault, and there is also risk to damage your computer.
Possible cause for the fault.
1 Faulty USB port on computer.
2 Defective USB cable.
3 Faulty control board on printer.
Things you can do:
Test a different USB cable.
Test the printer on a different USB port on computer.
If that does not work, the printer is sending a wrong voltage or data signal through the USB cable, tha printer can even work on a different computer, but there is always the risk to damage the computer.
Feb 23, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Restart
it is stuck in a loop, when it is rebooting turn it off at the power button on your pc.
Turn it back on, then it should say windows shutdown unexpectidely and then prompt you to start windows as normal, highlight it and press enter.
Sep 08, 2008 | Microsoft Windows XP Professional
Creepy 'USB' issues...
During setting up computer with drivers etc. System file could have become faulty some files not registered in System
You could have System file errors these files are the heart of O/S
whereas the reg is the blood if System file are faulty things do not work properly.
Go to C:\ right click properties / Tools / error check new box popsup
tick little box to fix errors and reboot
On reboot windows will check disk for errors and fix them
If this does not help please email me at thoughts001au@yahoo.com.au
Give a details description of what happens
Aug 27, 2008 | Compaq Evo D310M 845G P4 Motherboard
DX38BT don't boot after a recovery BIOS
hello ...you there....
what happened???why did the chat close??
Mar 07, 2008 | Intel Motherboard
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
