Question about Memorex (32023239) External Floppy Drive
Memorex External Floppy Drive Troubleshooting Forum
I can't get the external F:\ to burn the movie to DVD43,to Shrink to the hardrive C:\ and back to to F:\.It says I have to burn back to D:\ drive.Is there something wrong with the external burner?
    Sergeant:
  • 310 Answers
Is this a dvd re-writer or a external floppy drive as advertised? if its to copy dvds, install nero on the machine, then download a program called dvd shrink its free and can be found on google, put film in the drive, run dvd shrink, click backup, it rips it to c:\ then disc pops out and you put in blank dvd and :-) its done.. hope i have guessed what you mean correctly .. All the best John
Posted on Mar 13, 2007
Looking for external USB Floppy disk drive for windows 8?
From the issue description, I understand that external floppy drive does not recognize in Windows 8.
I will certainly help you with this issue.
1. What is the make and model of your computer?
2. What is the make and model of your floppy drive?
3. Are you getting any error message?
4. Were there any changes made to the computer prior to the issue?
Please follow the methods.
Method 1:
Run the troubleshooter and check.
a) Press the 'Windows + C' to activate the charms menu or move the mouse pointer to bottom right corner of the screen and you will get the charms menu.
b) Click on 'search' and select 'settings' and type 'Troubleshooting' and select 'troubleshooting'.
c) Click on 'Hardware and Sound' and select 'Hardware and Devices' and click on next to run the troubleshooter.
Method 2:
Please visit the manufacturer website of the device to install the latest drivers and check.
Sep 26, 2014 | SYBA USB Floppy Disk Drive (External) NEC...
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
How can i burn this
Putting a plastic device into a roaring fire is not good -- the burning plastic emits harmful chemicals. Instead, properly RECYCLE the drive.
Aug 06, 2010 | Toshiba - Floppy disk drive - external -...
Bought a new USB external floppy drive. Copied a
You may have a virus causing this...OR your computer USB MIGHT not be putting out the required 1/2 amp current. That you can fix by using a powered USB hub.
Dec 09, 2009 | Memorex Computers & Internet
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
I have a 20X Memorex multi function disk drive and have from time to time tried to use it for backing up/storing important data. My question is if I "verify" the burn there will be errors. I have also...
As for your question of disk vs hard drives, DVD's and CD's that are burnt from a computer are more easily damaged then hard drive data. The best idea if you are looking for a good backup solution is an external hard drive in my opinion. There are many opinions on this very subject so you will receive many opinions. There are no wrong answers just opinions and personal preference. Another solution you can try is an external HD using a program such as Symantec Ghost and create a full image of your hard drive.
Dec 18, 2008 | Computers & Internet
Memorex dvd burner 530l
Please read the following website. I think it will help you. Let know. Thanks. http://forum.rpc1.org/dl_firmware.php?category=1&manufactor=3
Jun 25, 2007 | Memorex External DL DVD Drive 18X Burner
Memorex (32023239) External Floppy Drive Logo
105 people viewed this question
Top Memorex Computers & Internet Experts
Jax Planet
Jax Planet
Gbenga
Dennis Gutowski
Dennis Gutowski
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
