Question about ATSI Holdings COGNITIVE (LDD42-2083-013) Label Printer
Cognitive Del Sol LX continually spitting out labels
When we attempt to print a label, it will print one then continually feed the labels through unless you switch it off or open the top. Can anyone help? Typical that this happens two weeks before christmas.
Thanks.
    Problem Solver:
  • 12 Answers
Try calibrating the printer. This can be accomplished through printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Posted on Jan 08, 2010
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Our DEL SOL BARCODE PRINTER won't print..it operates fine but the labels come out blank...any suggestions?
Is this the first time using the printer ? As simple as it sounds, make sure that the ribbon is not on backwards. ribbons have two sides, one with ink, one without. The ink side of course should be facing down to the label stock. If you are not sure which side has ink, just use a label to touch each side. Ink will come up in the adhesive from the ink side.
If the ribbon is on correct, then the next thing to check is the darkness setting usually set from the printer driver or label software. Maybe it's not set high enough for the label / ribbon combination.
Hope that helps !
Apr 23, 2010 | ATSI Holdings Cognitive Del Sol Thermal...
A small part of the label is faded out and the scanner can't read it. How do i fix it? Product: Cognitive Advantage LX label printer.
First, try cleaning the printhead with some isopropyl alcohol on a clean rag. If this doesn't work, send in for service.
Jan 07, 2010 | ATSI Holdings Cognitive Advantage LX BD24...
Our Blaster Advantage prints too low on label
Printer needs to be calibrated. This can be accomplished through the driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Dec 12, 2009 | ATSI Holdings Cognitive Blaster Advantage...
PRINTER PRINTS ONE LABEL THEN DISPENSES 4 TO 5 MORE BLANK LABELS. UNABLE TO RESET WITHOUT TURNING UNIT OFF AND REWINDING LABEL ROLL. WE HAVE A COGNITIVE LX THERMAL PRINTER.
Printer needs calibrating. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Oct 10, 2009 | Label Accessories Cognitive Thermal Label...
Blaster advantage printer does not print in proper spaces on labels
Try calibrating the printer. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Jul 29, 2009 | ATSI Holdings Cognitive Blaster Advantage...
We are facing the same problem
Jun 11, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Cognitive Blaster Advantage PROBLEM
Printer needs to be calibrated. This can be accomplished through the printer driver or setup utility.
Apr 10, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Printing off to one side after reloading drivers
Make sure the roll of labels are pushed all the way over to the left in the label bucket.
Mar 23, 2009 | ATSI Holdings COGNITIVE Thermal Label...
ATSI Holdings COGNITIVE (LDD42-2083-013) Label Printer Logo
463 people viewed this question
Top ATSI Holdings Office Equipment & Supplies Experts
jasbo
jasbo
Are you an ATSI Holdings Office Equipment and Supply Expert? Answer questions, earn points and help others
