Question about Daewoo CMC 710B Monitor
My screen is all messed up.
What are the red, green, and blue bias supposed to be at?
0 characters
1 Points
The screen turns green after playing videos for 20 minures
The Video Controller works off of the RGB principal. RED/Green/Blue pixels. The mix color is dependent on the formation and density of the pixel and rates. When one or more colors are absent the only functioning color will dominate, and it is Green in your case. The screen liquid crystals in Red and Blue are failing and only a screen replacement will fix the situation.
Jan 04, 2015 | Toshiba C655D-S5200 Amd Dual-Core C-50 3Gb...
There no diplay eccept lots of blue, red, green lines on the monitor, please help
Try another monitor if it works the way it should then it's the other monitor. If the result is the same reboot the computer in safe mode by tapping the f-8 key when you see fhe first splash screen choose safe mode. If it still messed up then you have a graphics problem. Take the computer in and have it tested.
Apr 02, 2014 | Samsung SyncMaster 540N 15" LCD Monitor
My screen is green i was going to change monters didn't work so i put it back and it turn please.
Red, Green, and Blue are the colors sent from your computer to the monitor. Sounds like red and blue are not working. If you've tried a new monitor, I'd try a new video cable next. Then clean the connector on the back of the computer (compressed air). Finally, replace either the video card or the computer.
Oct 04, 2010 | Computer Monitors
No yellow or blue color displaying
In a monitor like crt type. there are three colors amplifier. Red, Green and Blue. I think the Blue color amplifier is defective. Try check the biasing and also the transistor.
Feb 02, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Daewoo CMC 710B Monitor Logo
Top Daewoo Computer Monitors Experts
Paul Bade
Bob Sloan
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a Daewoo Computer Monitor Expert? Answer questions, earn points and help others
