Not able to install sound device
I have recently installed new hard disk and now i am now getting a p message that sound device not installed. i do not have any other disk except operating system (XP) disk. pls help me to solve this problem?
  • Anonymous Dec 13, 2008
    I have the same problem. the drivers do not work
Hi Ms.Geetha
First what you need to know what brand of sound card is ..,
This you will be able to know from Control panel -> sounds and Audio devices option
once u know the Type, U can down load it from net or
the very easiest is to take any Mother Board CD from some of ur collegues and run the
setup.exe from [sound] Folder in the CD
I think the soundcard present on ur mother board is not Avance AC'97, Xp comes with default drivers of Avance AC'97 Drivers.
this will solve ur problem...,
Posted on Jan 17, 2009
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Oct 30, 2012 | Toshiba Computers & Internet
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
Tip
NO BOOTABLE DEVICE
When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message - "No bootable device. Insert boot disk and press any key"
on Oct 02, 2010 | Computers & Internet
I have a Dell Inspiron 1525 and when I turn it on it tells me NO BOOTABLE DEVICE DETECTED This happen one other time and I rebooted my computer and it came back on but it did not work this time what can I...
There may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the hard drive and also where it connects to the motherboard.
Sep 16, 2012 | Dell Inspiron 1525 Notebook
How can i fix my acer 5515 smart failure predicted on hard disk 4 wdc wd1600bevt-22zcto-s1
This error message is warning that the hard disk could fail soon. It pays to back up your data frequently so when the hard disk fails you will not lose youe data.
The only way to fix this problem is to install a new hard disk, install Windows on the new hard disk and the Acer laptop's device drivers plus your programs and data.
Feb 18, 2012 | Acer Computers & Internet
Every time I turn on my computer the following message appears: "For PCIE Atheros Ethernet controller v1.0.0.5 Check cable connection ..! pxe-e63: error while initializing the NIC pxe-mof:...
It sounds like the hard disk is faulty, the machine is trying to boot via the network card as it cannot find a bootable disk. You could try removing the hard drive and reseating it but the disk could be dead.
Apr 04, 2011 | Acer Aspire One PC Notebook
When my computer starts it goes to a black screen and says "no bootable device jnsert boot disk and press any key" what can i do
Normal 0
This error message - "No bootable device. Insert boot disk and press any key" means -
The PC cannot see a boot file/disk on either the hard disk or floppy drive.
Check the floppy drive and remove and floppy disk.
If there was no disk in the floppy drive then it is a hard disk problem.
If it still gives this error message and the BIOS does not detect the hard drive, then the hard drive is probably faulty.
To get the computer working again, install a new hard drive in your computer and then install Windows on the new hard drive plus the computer's device drivers and your programs.
I recently installed new hard drive and have no sound
Identify your sound board - visit the manufacturer website ... search your model and get the driver. You can look in the Device Manager for this information. You may also wish to update or download the driver from within the device manager.
You may wish to go to www.pcpitstoplcom and have your computer scanned. The website will provide you with a free report on all aspects of your computer, software installed, memory, names of components and what drivers are installed and or missing.
This is a free service of PCPITSTOP, though they do sell stuff there. It is certainly worthwhile to take advantage of this free service.
If you need additional help with this, please let me know.
I hope you find what you need
a
Oct 15, 2009 | Audio Players & Recorders
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sound Drivers
you have to download the sound drivers and install the software..can't give you the exact driver as haven't specified much about your PC.
still try to download one of the common driver like realtek- Ac97... from the following URL ..
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
or try to download other audio drivers and install it...your problem would be fixed.
hope to get rated as fixed...
regards
bzoy
Dec 27, 2007 | Genius Soundmaker 32 Sound Card
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
