Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
LG Flatron L194WT-SF Will not turn on.
A week ago I was working on a word document then looked at a webpage then tried to come back to the word doc and my screen froze...couldn't go to my mail accts or back into the web or into word doc again. Got the screen to the windows start page and ran a virus scan then tried to restart computer. Windows start up screen came on then screen went black... took computer to be looked at and technician could only find a few minor viruses and he readjusted the screen resolution. when plugged it all back in I can't even get the screen to switch on. Have plugged all in, pressed blue power button on back and nothing happens. Is this the end or something simple I am missing?
  • 6 more comments
  • Anonymous Dec 25, 2008
    Mine too ;,
  • Germany95 Jan 06, 2009
    Same thing, the monitor will not turn on. This happen around 1 Nov 08.
  • Anonymous Jan 08, 2009
    same here and there are many more like us. I paid a lot for this monitor and would love some help.
  • yogipat44 Feb 14, 2009
    I HAVE THE SAME PROBLEM. TRIED ANOTHER MONITOR TO MAKE SURE IT WAS NOT THE COMPUTER AND IT WORKS FINE. JUNK MONITOR
  • Anonymous Feb 20, 2009
    Same monitor, same problem, had it about 9 months. Won't turn on at all.
  • Anonymous Mar 10, 2009
    Same, had mind little over a year. Trying to take it apart atm.
  • Hafrikan Mar 28, 2009
    Same Deal. It just went into Power Save mode one night and never came out of it. Now I can't turn it on ever. Crapsorz !!
  • Anonymous Mar 30, 2009
    will not turn on
mjcarrasquil
SOURCE: I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
Posted on Apr 27, 2009
  • 276 Answers
SOURCE: my screen keeps going blank after about 2 hours
check the flexible connectors conecciom tambein There is a false contact
Posted on Aug 21, 2009
budmrtn
  • 11361 Answers
SOURCE: My LGFlatron L194WT-SF monitor
No reset button, more likely to have failed power supply due to bad caps, tha twill be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 13, 2010
SOURCE: Hi My LG Flatron MDL L194WT-SF just stopped
They have an internal power adaptor which does contain a fuse. However the fuse is soldered to the board so you need soldering skills to change it. Also, if the internal fuse has gone then it's probably because another component such as the transformer has gone in which case it won't help.
Unless you know how to troubleshoot electronic boards a component level you're almost certainly out of luck here I'm afraid.
Posted on Nov 11, 2010
budmrtn
  • 11361 Answers
SOURCE: HOW TO CHECK A LG FLATRON L194WT-SF MONITOR
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194W&kategoria=monitor&kat2=all
After removing all the screws and the base, I use thin flat blade screw driver to crack open the case starting at the bottom egde and work your way around, just watch out for any cables attached to the front bezel. The monitor is not made to be easily open up.
Please read my guide so you will know what to look for inside the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 16, 2011
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
HOW TO CHECK A LG FLATRON L194WT-SF MONITOR FUSE, THE REAL PROBLEM IS HOW TO REMOVE THE BACK COVER
Mar 15, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
I just got my LG L194WT-SF with an older computer and dont know what hapin, but it dont turn on i have try'd difrent power cords but still no power ive seen outher people with same problem but no awsners..
Hi There,
It's used LCD Monitor, right? You can read my Tips about this kind of issue, just click here.
Let me know if there is not clear enough.
regards,
dm
Dec 16, 2010 | LG L194WT 19" LCD Monitor
LG Flatron L194WT Monitor no power
It can be as simple $5 worth of caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
http://www.badcaps.net
May 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Hi My LG Flatron MDL L194WT-SF just stopped working. no power surge or power outages. Can this be repaired or is there an internal fuse that may have blown. it is just like new and hate that it failed....
Jan 14, 2010 | LG Computers & Internet
My screen keeps going blank after about 2 hours
Aug 21, 2009 | LG Flatron L1710S 17" LCD Monitor
Apr 16, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
1,585 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
