Question about Waring WWM200PC Waffle Maker
Broken shaft The shaft between the rear post and the griddle of our Waring Pro WWM200PC waffle maker has broken. Can this be repaired, and if so are there instructions on how to do it?
I made a template of the shaft, cut out a sturdy piece of tin to straddle the break, and then screwed that piece in at both ends after securely fitting the break together. A lot of work, but the waffle maker works great!
Posted on Dec 14, 2008
I need a replacement handle for my Waring WMK300 Professional Belgian waffle maker. Where can I get one?
If it is out of warranty, you will need to ask for parts from a service center.
No one is offering broken, used or as-is WMK300 on ebay. Maybe you should try to sell your waffle maker on ebay as parts. Somebody must need the circuit board, for example.
May 19, 2010 | Waring WMK300 Professional Belgian Waffle...
Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Pro WMK300
go to the manufacturers website and contact by phone
Jan 23, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Wafflemaker power light comes on but won't heat up
My just over 1-year old WWM200SA did the same thing while I was cooking with it (used it about 5 times). I found a solution under the WWM200PC thread that the thermal fuse blew early. I tested mine and that's what happened. It is a cheap part, but I called Waring Customer service (800-269-6640) instead and they said to send it in for replacement.
Apr 21, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Jan 19, 2008 | Waring WMK300 Professional Belgian Waffle...
Mine too
Jan 13, 2008 | Waring WMK300 Professional Belgian Waffle...
Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Sep 02, 2007 | Waring WMK300 Professional Belgian Waffle...
WWM200PC Waffle Maker will turn on but does not heat up
I fixed one of these for a friend - the problem was an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
May 25, 2007 | Waring WWM200PC Waffle Maker
Waring WWM200PC Waffle Maker Logo
196 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
