Question about LG KG800 Cellular Phone
My phone keeps rejecting bluetooth files - LG KG800 Cellular Phone
    Problem Solver:
  • 3 Answers
The files are probably in formats that aren't supported by your handset..
Posted on Dec 13, 2008
How do I receive music via blue tooth from other phones
turn on bluetooth on both the devices and then in the sending phone go to that music file and go to option and then send option and then select via bluetooth the sending phone searches for other devices and list the phones that are available now select the name to which u should send the file and if you select send the other device will prompt you telling that you have a file and will ask whether to accept or reject once u select accept you will start receiving the file
Mar 10, 2011 | HTC Tattoo Cell Phone
I cant send music files to it via bluetooth it keeps telling me to delete memory and now ive deleted everything and it still wont let me send music files via bluetooth. I have a nokia navigator 6110
make sure that all of the files that you have sent before via bleutooth was move on your memory card.take a lokk at your phone memory on how much is the free space.because once you transfer file via bluetooth it uses your phone memory. check your inbox outbox and myfolders.delete or move the files that is in there.then try to send via bluetooth again.hope I explained it well.
Apr 15, 2010 | Nokia 6110 Navigator Cell Phone
How do I pair my wireless Jabra BTS30 headset with a new cell phone? It was paired to another phone before.
All that is required is to repair the headset with another phone. If you need instructions on how to place the headset in pairing mode, please let me know i will be glad to help =)
Mar 30, 2010 | Jabra Bluetooth Headset with Adjustable...
My iphone will not detect other bluetooth devices
there is no way to solve this, as the iPhone's bluetooth was designed to reject file-sharing devices, such as common cell-phones. It may be possible to force the bluetooth radio to connect to other phones through some kind of program. If you are willing to try and jailbreak your iPhone,i suggest that you read this tip and you should have access to the application iBluetooth. But as i never used it, i can't tell you how it works, but you can get it through this way:
http://www.fixya.com/support/r4066601-unrestrict_iphone_3gs_make_voip_calls
Nov 14, 2009 | Apple iPhone Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Change language ,send pictures via bluetooth on touch diamond 2
In order to send pictures from your phone to other devices via Bluetooth, the following steps should be taken:
• Access your phones picture library
• View the picture you want to send
• Hit the menu button
• Select “Copy” from the menu list
• Chose “Bluetooth”
• Hit “Yes” when it asks you if you want to temporarily turn on Bluetooth
• Select “Look For Devices”
• Once your phone finds the device and lists its name, you select that device name
• The receiving device is then prompted to accept/reject my file
• Once accepted, the picture is sent (takes about two seconds)
Jun 21, 2009 | HTC Touch Diamond Smartphone
Bluetooth Transfer Constntly Fails
You must have made the mistake of rejecting a transfer from the phone to PC previously.
I had this problem and the only way is to restore system back to factory setting and dont forget to backup your documents.
rate this fixya
Apr 12, 2009 | HP Pavilion dv4000 Notebook
My phone keeps rejecting bluetooth files lg kg800 bluetooth not working
You should rewrite this question under phones it is under air compressor forum hope this helps
Dec 28, 2008 | Air Tools & Compressors
Can i save files sent through bluetooth strait to my memory card on the lg ks360
o send a file via Bluetooth:From the Start-up screen select the Main Menu icon
Go to Multi-media (Figure 1)
Select My Stuff (Figure 2)
Go the images/sounds/videos/documents and select the file you wish to send
Select the Menu icon at the bottom left of the screen
Select Send Via (Figure 3)
Then choose Bluetooth (Figure 4)
You will then be presented with a list of devices in your area. (Figure 5)
If you do not see the device you wish to send your file to ensure it’s has Bluetooth switched on and select New
Your handset with then search for all Bluetooth devices in your area (Figure 6)
Select your device and your handset will send the file (Figure 7)
The Bluetooth device you are sending your file to must accept the file (Figure 8)
To receive files via Bluetooth ensure you have Bluetooth switched on – only accept files from devices you recognise.
You will receive a message stating the file name with the option to accept or reject the file
To receive select Accept (Figure 9)
The file will then be transferred to your handset (Figure 10)
It will then be saved in your images folder
Oct 18, 2008 | LG Cell Phones
LG KG800 Cellular Phone Logo
20 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
