Question about Canon PIXMA iP90 Mobile Printer
Error code 4 flashing orange - code 5c00
Ive had the printer flash 4 orange lights and get code 5c00 on laptop screen. so far ive cleaned the print head, the waste ink pads and tried the reset sequence without any joy. Can anyone explain to me what else i can try or have i missed something here? - im in the philippines at the moment and cant get it repaired under warranty here - i bought it in UK and the printer is barely 6 months old.
Thanks for any advise you can give
Chris
  • Tamedtiger Dec 13, 2008
    Cheers Xanda - but after a lot of head scratching i have finally got it working - its not a purge unit broken - it was the purge unit blocked from running with some paper jam debris which i just removed! lol - i am now one happy bunny!!! maybe we should post this as a possible problem solver - unhook the casing and check the right side gears near the ink waste pad - gently turn them to see if the mechanism's blocked - remove any loose paper and bingo - problem solved my ip90 is now printing like a trooper!!! what yah think - worth posting mate?
    Novelist:
  • 110 Answers
I also had this issue. The problem was that the 'excess toner cleaner' on the right side was stuck down and the gears could not turn to pop it up... I took the machine apart, and dislodged the part. Now it works fine!
Posted on Sep 17, 2009
  • chunyuchen33
    chunyuchen33 Aug 23, 2012
    how do you do that? how can I get the gears apart?
  • chunyuchen33
    mine is also the gears problem, but not quite sure how to take it off .
    Guru:
  • Canon Expert
  • 183 Answers
Hi Chris,
Error code 5c00 (flash in orange /green 4 times) indicates that purge unit has broken so that the printhead is locked down when initializing process performed. Sorry I have to say that no first aid for this problem unless you bring it to nearest service centre for part replacement. Hope this information helpful for you.
Regards,
Source:
Canon Inkjet Forum
Posted on Dec 13, 2008
  • Xanda Frederica Dec 13, 2008
    You are so lucky Chris!. Since this symptom indicates what I have told you. The broken paper prevent purge unit mechanical system from running. 5c00 description is Purging Operation Error while I seem to ignore some little possibilities like you experience. However, good luck and have brighter day.
I can not print. it shows an error messege on the lcd screen 5c00 and green and orange light flashes alternately.
The error code 5C00 is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925)
Nov 28, 2010 | Canon MP520 All-In-One InkJet Photo...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    count how many times the lights flash, here is what they mean
    Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
    Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
    Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
    Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
    Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
    Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
    Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Error code on my ix4000 reads 5C00
    Canon has a decent trouble shooting guide for this model:
    http://www.usa.canon.com/consumer/contro...
    Click on the Step-by-Step Troubleshooting link under Tech Support
    Unfortunately it does not give any possible solutions for blinking lights.
    The user guide on the other hand does.
    You can download this under Downloads -> Product / Software Manuals
    Here is a summary of what the flashing lights could mean:
    Two flashes: Out of paper or paper feed error
    Reload the paper correctly and press the RESUME/CANCEL button.
    Three flashes: Paper jam
    If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
    See Paper Jams
    Six flashes: No print head installed
    Install a print head.
    Seven flashes: Print head is defective
    Contact the Customer Care Center.
    Eight flashes: Waste ink tank almost full
    Ink used for cleaning is absorbed in the waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
    Important
    If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact the Customer Care Center as soon as possible. Once the waste ink absorber becomes completely full, printing will no longer be possible.
    Nine flashes: Ink tank is not installed properly
    Open the print head cover and press the button of the ink tank and reinstall the ink tank properly.
    Ten flashes: Battery level is low
    Charge the battery. For details on how to charge the battery, refer to the manual supplied with the battery.
    Eleven flashes: A specified period of time has lapsed without receiving a response from the digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
    Disconnect the camera cable, press the printer's RESUME/CANCEL button and reconnect the cable.
    If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use digital cameras or digital video camcorders that are compatible with this printer.
    POWER lamp flashes alternate green and orange:
    An error that requires contacting the Customer Care Center may have occurred.
    Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it about 10 minutes.
    If the problem remains, contact the Customer Care Center.
    Jun 19, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
    Canon i560 Ink jet Error Code 5C00
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    May 05, 2008 | Canon BubbleJet i550 InkJet Printer
    Error Message 5C00
    4 times is usually Automatic print head alignment
    Set a sheet of plain paper (A4 or letter) in the ASF.and adjust.
    Jan 14, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
    Canon BubbleJet i70 clatters like a rattlesnake when turned on
    Hi, didn't find anything in regards to the error code you mentioned. The flashing error light i did find something on though. The kind of error depends on how often the orange error light flashes (any # from 2 -10). You can read up on it in the user manual. Tom
    Aug 03, 2007 | Canon BubbleJet i70 InkJet Photo Printer
    Canon PIXMA iP90 Mobile Printer Logo
    716 people viewed this question
    old marine
    old marine
