Question about Garmin nuvi 205 GPS Receiver
Garmin Nuvi 205 keeps saying no maps available ???
Cannot use any other functions , have tried to reset , but to no avail , i thought the nuvi came pre loaded with maps??
  • 1 more comment
  • Lore1976 Dec 25, 2008
    I have the same problem with Garmin Nuvi 205. Its says that there are "No detailed maps found that support routing. The nuvi cannot be used without them".
    I have tried to update the nuvi online with no success. This is the 2nd nuvi I am having in less than 2 years. The 1st one froze and was replaced by the second one I got. I must say that the Garmin Nuvi 205 seems to be a hopeless product and I will not encourage anyone to buy it.
  • julie_uaw100 Apr 13, 2009
    i have the same problem with the garmin nuvi 205! im not tooo computer savy- tried to go back in and delete the 2009 maps and still getting the same results. just baught this darn thing 2 weeks ago. will best buy take it back if i have the reciept? cause that seems to be my only game plan now!
  • Anonymous Apr 21, 2009
    I downloaded the free update for the NT navigator 2010 maps then upon turning on my device it said that it could not work due to a lack of detailed maps etc...
This is easy. You have to run your software, select the maps tap and then transfer maps to the device. Chances are good you uploaded a 2009 map on top of the 2008 map. The updater doesn't delete maps.
Your unl file only has one key, you have two maps loaded. Simple go into the garmin directory and delete the map file and the mapsupp file. You can easily find them because they are greater than 500 mb.
Then run mapinstall (google for the file). This will install your most current map to the Nuvi. You are back in business.
Posted on Apr 12, 2009
First you will want to empty your recycling bin & clear your temporary internet files before re-downloading the Garmin_RMU_2010B.exe file.
Below is the remainder of the fix I received from Garmin support and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the end of setup.exe". For example the end would look like xxx\Setup.exe" -build_map_image 006-D0783-04
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be built. Leave the Window open till completion of all steps. 9a. Windows XP: Click on Start>Run, then type in %Temp%. Another window will open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have any trouble with this fix, or are not comfortable trying it please call our Software Support Department at 1-800-800-1020. Please be at a computer that has high speed internet access as we may need to log on to your computer to resolve the issue. Make sure you have the program extracted using the 7 zip program provided above. Hours of Operation Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
Posted on Apr 28, 2009
I have a garmin nuvi 2515 and it wont boot beyond the loading maps message
You will have to Reset it. This is from your manual. If the software and firmware is corrupted, I believe you have to return them. I have had 2 Garmin Nuvi and have had to reset once. It is a pain because you lose your bookmarks.
Resetting the Device
You can reset your device if it stops functioning.
Hold the Power key for 10 seconds.
http://static.garmin.com/pumac/nuvi_2405_2505_series_OM.pdf
Jan 06, 2016 | Garmin GPS
Garmin nuvi turns on, but goes black after attempting to load maps.
Try and connect the Nuvi to a PC / Mac using an USB cable. Connect the cable first before powering the PC / Mac - make sure the Nuvi is powered off.
Then turn on the PC / Mac. The Nuvi should go into communication mode making it possible to update the internet software (if available on MyGarmin.com). This might fix the problem.
If there's no software update available at MyGarmin.com - try a master reset. This will clear all user data (POI's / Favorites, Tracks, routes) going back to factory defaults.
A master reset is started by pressing the lower right corner for at least 20 seconds while pressing the power-on button once. A question appears to clear all user data.
Jul 10, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi 765T won't load maps. Fires up, gets to the horozontal bar indicating that the maps are loading, but then goes dark and repeats. Held the on/off button for 8 seconds, but unit won't shut off. Didn't...
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Apr 30, 2010 | Garmin nuvi 765T GPS Receiver
GPS doesn't boot up
I can help you fix your Garmin Nuvi 200W.
Getting stuck at the Loading Maps page or rebooting before finishing is a sign that the system software or firmware of your Nuvi has become corrupt.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 28, 2010 | Garmin nuvi 200W GPS Receiver
Will not access maps
I hope that helps.
___________________
Mar 27, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 260 will not go past the loading maps screen
There is a corrupt or missing file associated with the mapping thats causing it to lock up. When that file is missing, your Nuvi never gets to the routine for communicating with your PC. That's why your PC can't detect it.
I've fixed this problem before. The unit must be placed in PRE-BOOT mode, forcing Windows to recognize it and then using a specific program, reflash the firmware to an older version that doesn't care that the file is missing. The unit will then boot properly and you'll regain detection to the unit in Windows. Then you can repair/replace the missing files and then reflash back to the latest firmware.
Yes, its a pain and not an easy process to the novice.
- Jim
SHARCNET-USA
Sep 02, 2009 | Garmin Nuvi 660 GPS Receiver
GPS would not turn on
Have you already tried the webupdater or registred the device on garmin.com? There you should get an free mapupdate which could replace your broken maps.
Dec 01, 2008 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 610
500Mb internL MEMORY ONLY- LOAD MAPS TO SD CARD TILL 4 gB WORKING
Oct 27, 2008 | Garmin Nuvi 610 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
2,744 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
