Question about E-Machines T5082 PC Desktop
I have installed one 1gb chip into my emachines t5082 computer and it worked fine. So I got another and removed the original 512 MB chip from it and it won't recognize the second 1gb chip.
  • Leslie May 11, 2010
    what is the max supported ram for your comp.
  • 655 Answers
I'm assuming that your 2nd DIMM is the same type and speed as the 1st one you put in. If you are not sure, check and make sure that it is DDR2, 533MHz, PC4200.
If they are not the same, that is most likely the problem.
If both DIMM's are the same, remove them both and then put one of them back into DDR2 Slot 1. Start your computer and see if the computer recognizes the memory. Remove it and try the other DIMM in the same DDR2 Slot 1.
If both work OK, the problem is on your mainboard.
Posted on Jan 03, 2009
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
Emachines T5082 Adding 512Mb ram. Getting slot 0 installed slot 1 not installed.
Try swapping the memory in the two slots. It sounds like either one of the memory chips is bad or one of the memory slots is bad.
If you find that one of the slots is bad, then you might try just putting a 1GB Chip in the slot that works.
Apr 24, 2012 | E-Machines eMachines Desktop PC
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
Emachines t5082- i pulled out the 512 mb chip of pc2-4200 533mhz that came in in the computer stock, and replaced with two 1gb chips pc2-4200 533mhz ( the computer has a max of 2 gb via two 1gb max slots)...
1)Check for BIOS update from emachines. Older computer may need updated BIOS to handle the increased memory.
2) If it does start up but the computer crashes or it will not load windows, Verify the sticks are error free with a memory diagnostic program like memtest. If the sticks have errors, get them replaced.
Mar 18, 2011 | E-Machines eMachines Desktop PC
I have a L7VMM2 - Rev 2 motherboard with a Athlon 2400 processor. I have replaced the 2 x 256 Mb ram chips (PC2100) with 2 x 1Gb PC2700 chips. Total memory is reported as 1Gb (i.e. 2 x 512). I am (almost)...
Have you checked the posibility of 512 Mb limit per slot for your motherboard? This is often at some older mobos. The manufacture page for your mobo is here check the revision you own.
Stelios.
Feb 22, 2010 | EliteGroup L7VMM2 Motherboard
T5082 RAM upgrade
you should always use the same size ram chips, never mix sizes, this can and will cause failures
Jun 11, 2009 | E-Machines T5082 PC Desktop
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
E-Machines T5082 PC Desktop Logo
140 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
