Question about D-Link DI 514 Wireless Router (DI-514)
Lost my connection to wire less router , the phones were down last week and after that we have to plug into router
  • 41 Answers
Powercycle your homenetwork. this step works 90% of the time. to powercycle your homenetwork, shut pc down, unlpug the power cable from the router, then unplug the power cable from the modem. give atleast 10 -15 seconds for your devices to refresh the connection. then in turning them back on, replug the power cable for the modem first, with for the sync light be turn solid, replug power cable for the router, then turn pc on.. try pulling up websites, you should be online now. just in case you still can't, bypass the router and connect the modem straight to the pc first. try connecting online, if you can't configure the modem to go online, once done, connect the router back to the equation and reconfigure its settings. you the should be up and running. i can help more if you'll tell me what's the modem and the router..
Posted on Dec 14, 2008
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
DGN2000 My connection from my PC to my router was lost after I reinstalled windows XP Professional with s.p 2 and 3. I tried to connect with the router installation disk but it would not detect the...
Merceconstan,
I hate to be the bringer of bad news, but your router sounds like what those of us in the trade affectionately called "bricked".
Check the ip address of your computer. You can do this holding down the windows key and pressing the "R" key to bring up the run window. When that window is up type "cmd" and press enter. This should bring up a black window with a command prompt. At this prompt, type "ipconfig" and press enter. This will list all the IP addresses of your computer. If the address of your wired connection looks like 169.254.x.x when plugged into the router, then your router isn't "handing out" addresses, and is probably broken.
Your best option is to contact Netgear for a replacement if you are still under warranty.
Sorry.
Feb 20, 2011 | NetGear RangeMax WPN824 Wireless Router...
Earlier my laptop shut down with no warning even though the charger was all connected and plugged in. now even though the charger is plugged in everytime i try to turn it back on the needs to be charged...
This could be caused by several things, but try the obvious first. I just bought a brand new power supply, and in less than a week the customer called and said it stopped working. I suggested she take the cord from the old charger and try it - it worked - the brand new cord lasted less than a week. The other thing that could cause this is a bad connection on the end of the power supply, going into the computer. It could even be a bad power supply.The last thing I can think of is a bad battery that won't hold a charge.
Aug 12, 2010 | HP Pavilion dv4000 Notebook
Lost internet service on laptop
First, are you wired or wirelessly connected to the router? Is there any computer that is connected to the router aside from the problem one?
If you are wired connected to the router, try connecting the Ethernet cable into different LAN port of the router.
If you are wirelessly connected to the router, try disabling and re-enabling the WiFi of your laptop and try connecting again.
If there's another computer that's connected to the router and it can get online, then the problem is in your computer. Checked the Network properties of the problem computer and make sure that you are getting a valid IP address.
If you have two computers and both of them are not getting online, try connecting first one of the computers directly to the modem. If same problem occur, then contact your ISP.
If you can get online while directly connected to the modem, then turn the Netgear router OFF for about a minute and turn it back on and try again.
Hope this helps and have a good day!
Nov 29, 2009 | Computers & Internet
Router reboot too often needed?
Try testing it using a differrent router and monitor the connection period of that router during the week. If you still experiencing the same problem using the tes router. It indicates that it may be a adsl line related problem.
Jul 28, 2009 | Computers & Internet
Laptop with wireless network , dont know Security key .
hi,kelly008
what you need is what is called a W.E.P.key.you should have this on the bottom of the wireless router.the thing what plugs into the phone line.it must be typed in exactly the same.
best of luck
Jan 24, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Tiscali broadband wireless connection. Router modems last 6/7 wks then won't connect
Hi, have you got filters on all your phone lines, including  a sky box if using one?
Oct 20, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
D-Link DI 514 Wireless Router (DI-514) Logo
50 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
