Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
My Samsund DLP Rear Projection TV keeps turning itself off.
The TV keeps turning itself off, it occurs every five to ten minutes, sometimes more often. I have found that pointing a fan at the back of the tv where the buld is located seems to prevent this problem. This would suggest a problem with the TV's own internal cooling system.
When the TV turns itself off all three lights flash on the front panel
  • 3 more comments
  • Anonymous Jan 03, 2009
    i have same problem...help!
  • eldstruck Mar 08, 2009
    shuts off by its self puting a fan in the back helps keep it on
  • Anonymous Mar 13, 2009
    ughh i have the samne prblem,, ill gett back with the resulrt
  • rcck00 May 23, 2009
    Same problem. Just replaced bulb 2 weeks ago. Was working fine, then started having problems turning on, and now turns itself off every two minutes or so. So frustrating. Any help? Thanks.
  • wardlovett May 11, 2010
    Can you please tell me exactly where power supply pcb is for Samsung HL-S6187W?
    Genius:
  • 1,694 Answers
Solder bad connections on power supply pcb.......T.
Posted on Dec 17, 2008
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
Powering on and off
I must say this is a wierd problem here. First of all, make sure that the T.V. has enough space, and the cables arent layed on each other, give each cable its space. Now, try to check the main T.V. cable, is it strongly plugged in? because it should be, might be that your cable is weak and gets loose sometimes, so try to plug it in in a strong way. Keep me informed.
Jul 22, 2007 | JVC AV-56WP30 56" Rear Projection...
Shutting off and turn back on ever five to ten minutes
Did you replaced lamp in Hitachi 60VX500 tv in last 2-3 years?
If not then it is time to replace lamp to solve tv issue.
Let me know if you have additional question.
Thanks.
Nov 28, 2010 | Hitachi 60VX500 60" Rear Projection HDTV
The tv turns itself off periodically. Sometimes it goes for hours and other times it happens several times in a 5 minute period.
I suspect a bad connection/dry joint in the power supply.
Look for regulator I/c's on heat sinks. They are favourite to get dry joints and anything that is heavy like transformers and chokes.
Oct 18, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Why does my Samsung DLP tv turn off by itself, sometimes after 1-2 minutes?
Either the lamp is aging or the vents are blocked causing the thermal sensor to over heat.
Jun 22, 2009 | Samsung HLR5064W DLP Projection TV
Tv turns off after 5 to 10 minutes
Go to menu and make sure there is no sleep time set in your TV set.
Thanks
Oct 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
RCA TV
Solder bad connections...main board with hv transformer on it..
CL035 capacitor and any others...use magnifier........T.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
759 people viewed this question
Henry  Thomas
Henry Thomas
