Question about Nikon Coolpix SQ Digital Camera
Nikon coolpix sq system error
Trying to switch on the camera I received system error message.
How to solve this problem?
Many thanks
Rosario
5 Suggested Answers
robmcd27
  • 423 Answers
SOURCE: Nikon Coolpix L18 Driver
Try this, it may work without the software.  Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key.  They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
Posted on Feb 18, 2009
olasNick
  • 20 Answers
SOURCE: system error message nikon coolpix 950
Any good with a small screw driver?
Posted on Apr 23, 2009
leethedeuce
  • 4472 Answers
SOURCE: "Lens Error" message in Nikon Coolpix L5
There are a few different things it could be though most likely the lens itself is out of alignment. There are methods you can try to "click" it back into place. First off how long have you owned the camera?
Thanks,
Lee
Posted on Sep 14, 2009
  • 11967 Answers
SOURCE: Nikon coolpix s220 camera driver for windows 2000
You don't need the driver...just get a card reader to download your pics to a folder you create on your desktop.
Posted on Feb 20, 2010
yo5bdm
  • 81 Answers
SOURCE: I have a Nikon Coolpix 8800 with a "System Error 2"
Check the memory card. It's probably damaged. If not it should be a software error, and you have to take it to the dealer where you purchased it from
Posted on Apr 06, 2010
System Erorr
Checkout this tip about digital camera error messages
Lens Error fix for Digital Camera
heatman101
Apr 26, 2011 | Nikon Coolpix SQ Digital Camera
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
SYSTEM ERROR
dont know about the reset button, but i had the same system error message with my camera, which has been in a drawer for 3 years since i got the message. just found it tonight, was researching it and apparently coolpix lenses tend to stick, found some references to other models(not sq). i decide to try taling it apart to have a go at the lens, but tried the easier and more satisfying turning it on and off 6 or 7 times while banging on the body beside the lens, which seems to have worked. systems error gone , camera turns on, i've taken 20 or so pics, no probs so far.
Jul 30, 2008 | Nikon Coolpix SQ Digital Camera
System error
http://www.fixya.com/support/t248852-sytem_error
Mar 17, 2008 | Nikon Coolpix 4600 Digital Camera
System error
My camera has been sitting in a drawer since 2005, found it tonight and decided to try take it apart to see if the lens was stuck ( apparently this is a problem with nikon coolpix), but before i did ( couldn't find screwdriver) decided to try gentle brute force. i turned it on and off 6 or 7 times while banging on the body beside the lens (to the left if looking at the screen) and it seems to have worked. Systems Error message has gone and i've taken 20 or so pics. i was actually looking here for a solution earlier today, so here you go guys
Dec 07, 2007 | Nikon Coolpix SQ Digital Camera
Coolpix sq
i had same problem, as a result camera has been in a drawer since 05. decided to try taking it apart tonight, while researching found other models of coolpix tend to get sticky lenses, before taking it apart turned it on and off 6 or 7 times while banging on the body beside the lens and it seems to have worked. camera turns on, takes pics, and systems error message gone. a good bang solves many problems
Dec 06, 2007 | Nikon Coolpix SQ Digital Camera
System error
turn it on and off 6 or 7 times while banging on the body beside the lens. worked for me, cameras been out of commission for 3 years ,apparently lenses tend to stick on coolpix cameras
Dec 17, 2006 | Nikon Coolpix SQ Digital Camera
System error
turn on and off 6 or 7 times while banging on the body beside the lens, worked for me, apparently coolpix lenses tend to stick, as my girlfriend says " a good bang will solve many problems"
Dec 06, 2006 | Nikon Coolpix SQ Digital Camera
Nikon Coolpix SQ Digital Camera Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
