Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
No power to dishwasher
I have a kenmore built in dishwasher part number 154520101 and i have had no problems with it. tonight i loaded it and can not get it to power on. i unplugged it and plugged it back in. i also checked the breaker box and it was fine. do you have any thing else i could try. thanks... mark
4 Suggested Answers
SOURCE:
reg501
  • 413 Answers
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
SOURCE: Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
Posted on Jul 18, 2008
MNfisherman
  • 11896 Answers
SOURCE: I need to see how
You can go to partselect,com and type in your model or part number and it will show you a diagram of exactly how it goes together
Posted on Oct 20, 2010
My kenmore elite dishwasher is brand new but tonight it is flashing locked and I can't get it to do anything
Some times just turning off the power for a few minutes will reset the program--if not, in your instructions you should find what the flashing light is an indicator of--
Jul 14, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Tip
Thank God for smart people and information on the internet!!! We just moved into...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Oct 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher does not start
I had this problem and solved it by merely switching the associated circuit breaker off and on again. Something of a "hard reboot." Annoying ... and ... if it happens repeatedly (tonight was the first time), someting I will pursue fixing while hte d/w is still under warrwentey (It was purchased/installed less than three months ago.)
Dec 12, 2012 | Kenmore 18" Built-In Dishwasher -...
I have a Kenmore dishwasher am not sure of the model number it is a Kenmore Elite with stainless steel interior. i am using Cascade advanced power liquid detergent and am getting over a time a black...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 25, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore 18 in. dishwasher is not spraying water and the sprayer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 25, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
This dishwasher has worked fine for years. Suddenly, no power at all to front controls, won't start. There is power at the plug. Any ideas?
Kenmore and other Whirlpool manufactured dishwashers have a thermal fuse located inside the operator console. If the fuse blows it will exhibit the symptoms you describe. It cannot be reset and must be replaced. If you post back with your model number I can confirm how your dishwasher is configured and maybe provide you with a part number.
Dec 11, 2009 | Kenmore 15879 Built-in Dishwasher
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
Kenmore Elite 15962990 will not start
So far, I'm not very impressed with this website. I posted a problem with a Kenmore Elite 15962990. FixYa emailed me back, saying: "We wanted to find out if you still need a solution for the Kenmore 24 in. 15932 Built-in Dishwasher Problem". So now I'm confused. I'm supposed to trust advice from somebody who can't even get the model number right? And FixYa keeps telling me I'm dealing with a top load clothes washer instead of a dishwasher.
Anyway, the problem still exists. I know there must be some way to reset it or put it in "maintenance mode". But none of the button sequences I saw online will work because my specific model does not have the buttons mentioned.
Feb 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
49 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
