Question about Aiwa Audio Players & Recorders
Aiwa sterio radio cassette player - model HS-T900 . This player is rechargeable (battery PB-3). It is some years since I dropped the cassette and damaged the crystal display screen so that NO information is now displayed. Inputting the above model No. shows that this headphones?? Can this cassette be repaired?
Schrody
  • 17 Answers
SOURCE: PACKARD BELL CD/RADIO/MP3 PLAYER. MODEL PB OP 10
This is not for connecting an MP3 player, but rather for playing MP3-CD's. Using your computer and a CD burner, you can burn a CD with up to about ten hours worth of MP3s on it. The procedure for creating the disc varies depending on your burning software. In Nero, for example, you would select "Music" and then "MP3 Disc" and then select the songs you want to put on the disc. For other software you just select "burn a data disc" and then select the MP3 files you want.
Once you have a CD full of MP3s, put it in the Packard-Bell stereo's CD player, and you will be able to play all the MP3 files that are on the CD. THe advantage, of course, is being able to put ten hours on one CD instead of only 80 minutes.
Posted on Feb 14, 2008
leethedeuce
  • 4472 Answers
SOURCE: LCD display - BMW x5 3.0i
You will want the factory service manual for the vehicle. You can contact your bmw dealer directly. If you would like I can try and locate one for you.
Thanks,
Lee
Posted on Jul 07, 2008
SOURCE: Nikon Coolpix P60 - Screen
I have the same exact problem with Guest on July 1, 2008. I am sending my camera in on Monday for repair. Have you had any luck getting yours fixed?
Posted on Sep 05, 2008
betz73
  • 298 Answers
SOURCE: Hi, I have a Hatachi AXM89MP3uk
it may have been over loaded, try to unplug it for a few seconds then plug it back in, this should reset the amp in the tuner it self.
Posted on Oct 23, 2008
  • 170 Answers
SOURCE: Mazda 3 (2006) Information Display panel is blank
06 MAZ 3 check the fuse marked ROOM15a ,,under the hood in the corner of the fuse panel, PULL IT OUT and change it whether blown or not ,,,,,should fix it ,,,,,,,,if the display is not bad
Posted on Jan 24, 2009
Aiwa AD F660 cassette deck. Having changed the drive belts, the eject button does not now work. Hook holding the cassette door shut does not drop enough to release. How can I fix this? Thanks, Brian
Have you trapped wire or something near the hook mechanism stopping it from getting full travel when the button's pressed?
The nice people at HiFiengine have a service manual for the deck, free you just need to join.
HTH
Aiwa AD F660 Manual 3 Head Stereo Cassette Deck HiFi Engine
Jan 19, 2018 | Aiwa Audio Players & Recorders
Have a cassette walkman that will only produce sound on one side of the headphones when jack is put into the outlet for the headphones. i know it's not the headphones because i've tried other ones too...i...
Hi ya
Well Aiwa stereos are very hard to open and designs to break when opening, however some models can be opening without too much issue.
So before you try to open the item, try these if you have some switch cleaner or alcohol tape head cleaner - put a little drop onto the headphone jack and insert and move around the socket just incase there is dirt on the contacts inside, also clean the tape head too just incase of the same,
if not then its an open up, sometime the solders come loose, so with a soldering iron just warm the solders up a little this may fix it.
if this does not it may be a broken part inside the jack - they can be replaced but not easy - spares can be got from ebay from china, for about 1.00gbp
hope this helps
Feb 14, 2014 | Aiwa HS-PS40 Personal Cassette Player
AIWA HS-J470
Go to support on the AIWA website and download an owners manual.
murf427
Aug 29, 2012 | Washing Machines
Aiwa TX646 user manual
I suggest search under manufacturer's website, they often keep downloadable pdf versions of the user manuals of all of their products hosted there: http://www.aiwa.com
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 18, 2011 | Aiwa HS-TX686 Personal Cassette Player
Manual for Aiwa TX646
Go to Manualfix.com. If they haven't got it, they'll get it.
How do I get my HS-TX686 to go into continuous auto reverse?
Look in the operating instructions which you would find by searching "Aiwa HS-TX686 manual"
http://www.retrevo.com/support/Aiwa-HS-TX686-manual/id/1077bh447/t/2/
Under "Playback"
Aug 13, 2011 | Aiwa HS-TX686 Personal Cassette Player
NEED A NEW BATTERY
how much is the price of a new batt.?
Jun 13, 2010 | Aiwa AM-F70 Personal MiniDisc Player
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
141 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
