Question about Panasonic CQ-C1303U CD Player
CQ-C1303 does not run FM stations with even no. frequencies
It runs FM stations with odd frequencies.can i get help?
DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
Mar 30, 2008 | Audio Players & Recorders
How do i set radio stations
Albeit you may be able to show even numbers on the dial, a standard stereo will only allow odd number stations to be programmed as those are the only ones available on the standard FM frequency.
Sep 05, 2014 | 2008 Chrysler Pt Cruiser
Bose 321 does not tune to every frequency. i want fm 98.0 but it doesn't stop there even with manual tuning. it goes from 97.9 to 98.1...
What is the FM radio stations call letters and city location? There are no . (point) numbers in the states that are even as far as I know. All odds as in 79.9, 80.1, 80.3, 80.5, 80.7...etc.
Nov 03, 2013 | Bose Audio Players & Recorders
Fm touner act only on odd number like 104.1- 104.3
factory radios only tune into odd numbers... radios stations broadcast on odd numbers to avoid some frequency interference... ive only see a few aftermarket radios that tune to even numbers also
Nov 03, 2009 | 2004 Chevrolet Blazer
The radio does not search on even numbers (89,8) only on odds numbers (89,9) is it posible to chance that?? My car is 2006 Tacoma
Why? North American radio stations are only broadcast on "odd" frequencies - x.1, x.3, etc.
Jul 12, 2009 | 2008 Toyota Tacoma
SONY CDX-SW200 only tunes into odd frequencies?
Not unless he unit is capable. I know that Cadence made their decks with this feature, and I haven't seen anyone else as of a year ago.
Jan 26, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Pioneer DEH-P690UB FM tuning problem
Pioneer have factory set your DEH-P690UB to 0.2Mhz steps to match the American FM frequency allocations. The fix is not casual as it requires complete disassembly of the head unit and repositioning of two surface mount resistors. This will void any warrantee and unless you're good at microscopic soldering could also ruin the set. I did however void my 2 year warrantee yesterday partly out of frustration and because I have the right SMT tools at work. Now my tuner CPU thinks it's in the Austrailian/Asian model DEH-P7950UB and is also compatible with UK stations. A previously hidden menu is also available where I can set either 0.1 or 0.05Mhz stepping for FM and 9 or 10KHz for AM BSM scanning. The rotary control now steps in 0.05's instead of odd 0.2's on FM Hope this helps.
Aug 23, 2007 | Pioneer DEH-P690UB CD Player
Problems with FM with
That is very typical of tuners designed for the US market; US FM radio stations use only the odd numbers. In most cases, tuners made for the US cannot be adjusted for use in other countries. However, a few have an "area" control that can be switched; usually it's part of the setup menu. Check out your owner's manual, if it's available.
Jul 09, 2007 | Pyle PLCDUSMP74 CD Player
Radio recieves only odd frequencies
turn radio off, and press the "audio" botton until clock is displayed. then click it again shortly till you see "FM 100" on the display, press > (side arrow, now it should switch to "FM 50". long press on the "audio" to save and exit. afterwards it should work fine.
Feb 22, 2006 | Pioneer DEH-345 CD Changer
Panasonic CQ-C1303U CD Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
