Question about Canon PC1061 Copier
Error message E100
I'm getting an E100 error on our machine.The scanner light only goes halfway, and returns to the starting position and then the E100 error comes up.I was an electronic technician for twenty years, but I have never repaired a printer copier before-I am currently a business owner/partner and if possible, I'd like to repair it myself whether it is an electronic or mechanical problem.Thank you!.......dr
  • Anonymous Jan 22, 2009
    as with the others, my copier comes on, asks what size page I would like, then the alarm sounds and the error message E100 comes up; it is then impossible to perform any function at all or to get any button to respond. I have tried turning the machine off however the same situation just repeats and repeats. I have only just bought the copier second-hand and have not been able to use it at all; could the move have caused the problem....according to the previous owner it was in perfect working order and had recently been serviced, thank you.
The problem of the E100 is located in the BD of the machine that is in the regulation of the intencidade of the laser, page 5,16 of the manual of service of GOING 600.
Posted on Mar 19, 2007
  • angelikagarz Oct 26, 2010
    I had the same Error E100 and all I did was have a tech come clean the machine and whoohoo it started working again.
    New Friend:
I had the same problem after i move to my new place. my printer just keep showing the same error e100. i clean my printer a bit and reseated my Toner Cartridges and now the error is gone.
Posted on Apr 03, 2013
  • 944 Answers
Sorry I couldn't find a free one anywhere, but here you can get the service manual for all the other canon pc models for $11.99 if that would be any use to you; Also had no luck with a user manual, canon do not appear to acknowledge this product on any of their sites that i have found although it is listed in many other places. It does sound like a mechanical problem though - somehow the drive belt or pulley is out of sync, blocked by something or damaged - Hope this helps :)
Posted on Mar 11, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 11, 2007
    ignore that first one
    you still have to pay but it looks like a safer bet
    (401 page document - so good luck)
    Hope this helps more
  • Nigel Ridehalgh
    if you need any parts these guys seem to have the lot
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Dec 14, 2011 | Canon Office Equipment & Supplies
Error message E100. How do I repair or reset the machine?
E100 Scanner unit failure
Cause: (1) Poor contact in the laser/scanner unit connectors(2) Defective laser/scanner unit(3) Poor contact in the ECU board connectors(4) Defective ECU boardSolutions: (1) Reconnect the BD board connerctor (J871), laser driver board(J801), and scanner motor connector (J851).(2) Replace the laser/scanner unit(3) Reconnect the ECU board connectors J913 and J914 correctly.(4) Replace the ECU board.
Aug 12, 2011 | Canon 730i Laser Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Jul 29, 2011 | Canon LASER SHOT LBP-2900 Printer
How to unlock my M20i scanner
Release the lock, down the scanner is a tiny plastic piece between the oupt tray (the place where the paper goes out) and the top of the scanner
Fosg2000, Rate me please
Mar 16, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Dec 31, 2008 | Canon PC-1060 Black and White Copier
Machine error AE on brother MFC 6800
The error is from the scanner. It is possible the scanner lock on the underside of the scanner has shifted and not allowing the scanner to correctly return to the home position. Try Checking the scanner lock and make sure it is not in the locked position. Then turn off and on your machine while holding the menu/set button. the machine will come up either with an error or in maintenance mode. either way enter 99 and see what you get. Maintenance mode is a dangerous place to play around in. 99 exits maintenance mode. 91 resets all parameters to factory setting except stored locations like phone numbers and location information. 01 resets every thing to factory. DO NOT CHANGE ANYTHING IN MAINTENANCE MODE. CCDHP is scanner home position sensor. It will probably reset just by turning the machine off and on.
good luck.
Nov 01, 2008 | Brother MFC 6800 All-In-One Laser Printer
I am receving error messages E301 or E100
E100 - 001 and 002:
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
• The laser driver PCB has a fault.
The scanning lamp intensity has a fault.
• The scanning lamp has a fault.
• The CCD PCB has a fault.
• The DC controller PCB has a fault.
Seems to that you have issues with dc controller pcb
Oct 04, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
System Error E100
Sry it is a laser scanner error on almost all machines usually requiring the laser to be replaced
Apr 22, 2008 | Canon FAX-L400 All-In-One Laser Printer
Scanner belt slipping
Check flatcable connection to main circuit board:
Open cover and release the "Z" cover (right side) which hides the flatcable. Simply stick the cable to mainboard.
Feb 20, 2008 | Brother MFC 240C All-In-One InkJet Printer
Canon PC1061 Copier Logo
2,860 people viewed this question
old marine
old marine
