Question about Saeco Magic De Luxe Espresso Machine
Tip is broken - Saeco Magic Deluxe Expresso, Coffee Maker
The tips are the part that pulls down or raises up (1 piece)toward the cup when you are filling a demitasse cup or a full size mug. Can I find a replacement part?
    Problem Solver:
  • 8 Answers
In the UK Saeco parts are supplied by Gaggia UK in Halifax
Posted on Jan 09, 2009
I have a saeco magic comfort +. It is, all of a sudden, not going thru the rinse upon set up. Then, it is not putting water thru the grinds, and, thus, pushing all grinds dry to waste, not generating...
Hi
Don't really like the rinse cycle because it waste water. If you want to rinse the brew unit just push the "scoop button" and not put any coffee in, then push the large coffee. Does the same thing but doesn't use as much water.
Dry grounds is one of my tips.
http://www.fixya.com/support/r4084157-dumping_dry_grounds_not_making_coffee
Jul 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
The "funnel" piece underthe cup
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
May 18, 2011 | Keurig B66 3-Cup Coffee Maker
I need to replace the coffee dispencer part where the coffee actually comes out of into the cup on my 1999 Saeco Magic Deluxe, the part is $13 AU, is this an easy part to fit?
There are a number of Saeco Magic coffe machines from this company.
The best site for parts I have come across is listed below, I suggest that you look at this site to find your correct model:-
partsguru.com/SaecoBrewGroup.html
Regards
Alan Hood
ami-man
UK
Apr 09, 2010 | Saeco Magic De Luxe Espresso Machine
Water pump in Saeco Magic Deluxe
If you haven't cleaned the brew group, or decalcified the unit I would start there. This is something I do every 4 to 6 months (or anytime I notice the flow of coffee to start to slow down). This normally restores the flow to the original flow level. If you have already done these things you may want to give Saeco support a call and see what they suggest. They are extremely helpful, although very difficult to get on the phone as the phone system they use is horrible and hangs up after you hold more than a certain amount of time.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
My Saeco magic grinds the beans, but no coffee comes out. Sometimes it makes one cup, and skips. Other times, I grind the equivalent of 8 cups of coffee without any cups of coffee coming out.
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Where can i get a copy of the manual for the saeco magic deluxe automatic coffee maker?
Guess you should be able to get it from SAECO website. If not, there are some specialized manual search agents. Try manualfox.com - they worked good for me.
Aug 24, 2009 | Saeco Magic De Luxe Espresso Machine
Coffee not dispursing
Puddle under the machine means the boiler has broken. Whatever you do do not use the machine any more as the boiler could spray the pc board. If that happens your s.o.l. as saeco does not carry the board any longer. You can send it to a service center and have the boiler replaced. Lowest charge i've seen is $180.00 usd plus shipping and service charge. The boiler always breaks due to hard water and calcium buildup threw the machine and not descaling it. Also happens when machine is left on 24/7. If you have the boiler replaced, use only bottle water and turn off the machine when not in use. Also the machine MUST be descaled bi monthly.
Apr 07, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco vienna superautomatica
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Jan 23, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
90 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
